Elasto
Elasto [message #69948] Mon, 17 June 2013 11:55 UTC Go to next message
avatar recklesstryg  is currently offline recklesstryg
Fresh out the printer. Just have to give it a dye job and it will protect my iPhone 5 from falls.
I have been waiting for elasto material so I could do a case right
http://farm4.staticflickr.com/3753/9009589617_0dc37e4d89_z.jpg
http://farm9.staticflickr.com/8420/9010771802_c9588ac1c3_z.jpg
11 June 13:The Case had to have a few minor dremal adjustment for a good fit (This is my fault I forgot to update the file)
Update: Prep for Dyeing
Following:<a href=" http://blog.makezine.com/2013/05/09/how-to-dye-your-3d-print s/" target="_blank"></a>
Step 1: Soaking (make sure the item is cleaned off first)
http://farm3.staticflickr.com/2869/9016122576_8e19ef6cb1_c.jpg
Step 2: Dye
Follow the instructions
Boil water
Mix with dye
Submerge item
http://farm4.staticflickr.com/3672/9019604025_950d2fe4bf_z.jpg
I waited 30 mins
Step 3: Remove Item from Dye and into boiling water
this step removes excess dye
http://farm4.staticflickr.com/3816/9021365184_74297366e0_z.jpg
http://farm6.staticflickr.com/5343/9021362734_89875ed555_z.jpg
Step 4: Let it Dry
http://farm4.staticflickr.com/3736/9021360778_57e0baa4e5_z.jpg
Step 5: I used a rustoleum clear plastic paint to seal in the dye
http://farm9.staticflickr.com/8136/9021801194_070ee4bd6d_z.jpg
http://farm8.staticflickr.com/7303/9019572125_682182bd91_z.jpg
Re: Elasto [message #69969 is a reply to message #69948 ] Mon, 17 June 2013 17:58 UTC Go to previous messageGo to next message
Looks pretty good. Thanks for the details. I was thinking this material would be good for a phone case and that does look to be so.
Re: Elasto [message #69970 is a reply to message #69969 ] Mon, 17 June 2013 18:14 UTC Go to previous messageGo to next message
It is great for a phone case.
Re: Elasto [message #70165 is a reply to message #69948 ] Thu, 20 June 2013 14:21 UTC Go to previous messageGo to next message
avatar hazy_v  is currently offline hazy_v
I like that case man, very sci fi, and the dye is brilliant! Any thoughts on using a paint brush to apply the dye?
SHAZAM!
Re: Elasto [message #70169 is a reply to message #70165 ] Thu, 20 June 2013 15:16 UTC Go to previous messageGo to next message
I did not paint on the dye. I soaked the case overnight in water, then boiled water then added dye and submerged the case in the dye water for 30 minutes.
Re: Elasto [message #70180 is a reply to message #70169 ] Thu, 20 June 2013 16:30 UTC Go to previous messageGo to next message
Oh I'm sorry, I understood your procedure, but I have an elasto model needs to be two colors, sounds like the dye won't hold without boiling though.
SHAZAM!
Re: Elasto [message #70187 is a reply to message #70180 ] Thu, 20 June 2013 17:00 UTC Go to previous message
hazy_v wrote on Thu, 20 June 2013 16:30
I brought the water to a boil and then let it sit in the solution for 30 minutes while the solution cooled down. Depending what you and tring to do, either masking off and/or only susspending a section of the model might work.
Previous Topic:The little surfer
Next Topic:Prototypes – for Silver
