Opinions on how this will turn out
Opinions on how this will turn out [message #69713] Wed, 12 June 2013 18:58 UTC Go to next message
avatar timramich  is currently offline timramich
http://www.shapeways.com/model/1151697/0805-leds-front.html
I will do some kind of black. It is to isolate LED lights from each other for a spectrum analyzer. The smaller space between each element is 0.75mm. It doesn't need to be super accurate. It also doesn't need to be strong because it will be epoxied onto a PCB and the holes will all be filled with epoxy. Then the face will be ground flat. It will become a solid object. Should I use strong & flexible or detail?
Re: Opinions on how this will turn out [message #69760 is a reply to message #69713 ] Thu, 13 June 2013 16:05 UTC Go to previous messageGo to next message
No one?
Re: Opinions on how this will turn out [message #69762 is a reply to message #69713 ] Thu, 13 June 2013 17:22 UTC Go to previous messageGo to next message
How big are the holes?
Re: Opinions on how this will turn out [message #69766 is a reply to message #69762 ] Thu, 13 June 2013 17:42 UTC Go to previous messageGo to next message
It would probably easiest answered with this:
http://timramich.com/crap/0805hole.png
Re: Opinions on how this will turn out [message #69846 is a reply to message #69766 ] Fri, 14 June 2013 18:52 UTC Go to previous messageGo to next message
Those are the dimensions of each hole. 20 of them in each direction. There is a 0.75mm wall between each on the Y axis, and they are 8mm apart on center on the Y axis, so 3mm from each tip. The model is linked to and is downloadable.
[Updated on: Fri, 14 June 2013 18:54 UTC]
Re: Opinions on how this will turn out [message #69847 is a reply to message #69713 ] Fri, 14 June 2013 19:08 UTC Go to previous message
I don't think WSF would be a good choice as wall thickness can cause holes to close. Check out this extensive examination of results. I would go with FD or FUD for best results.
Previous Topic:Ball and cylindrical joints
Next Topic:Model Complexity
