Now Through Sunday Night. Black Friday Deals & Free Shipping! See the deals.
Home » Community » Instructions » Instructions for ETS35 update sets (for Hotckiss and Renault) (1:35)
Instructions for ETS35 update sets (for Hotckiss and Renault) (1:35) [message #54416] Sun, 23 September 2012 10:26 UTC Go to next message
avatar ETS35  is currently offline ETS35
These are the instructions for the following sets:
ETS35001
ETS35002
ETS35003
The 2nd post holds the instructions for ETS35007, the Renault R35 set.
The 3rd post holds the instuction for ETS35008, the APX-R turret.
Some general (hopefully useful) thoughts on working with printed parts made of 'Frosted Ultra Detail' can be found at the bottom of this message. We recommend you read this before ordering an item.
index.php?t=getfile&id=20985&private=0
index.php?t=getfile&id=20875&private=0
__________________________________
[Updated on: Fri, 06 September 2013 12:43 UTC]
Re: Instructions for ETS35 update sets (for Hotckiss and Renault) (1:35) [message #69501 is a reply to message #54416 ] Sun, 09 June 2013 09:04 UTC Go to previous messageGo to next message
Here are the instructions for ETS35007. More details will follow later.
However it might already be important to know this:
- Parts 21 can be used the holes in the idler (Part 22). These can simply be glued to the outside of the idler, but they are optional since not all R35s had these.
- Parts 28 and 29 are use to put Part 30 either in the closed or open position. You'll need some thing styrene rod or wire to attach these to Part 27
- When installing Part 37, make sure it ends up in a horizontal position. The upper hull of the R35 slopes down towards the rear, suggesting Part 37 should do the same, but it shouldn't.
index.php?t=getfile&id=34045&private=0
index.php?t=getfile&id=34044&private=0
Re: Instructions for ETS35 update sets (for Hotchkiss and Renault) (1:35) [message #74331 is a reply to message #69501 ] Fri, 06 September 2013 12:40 UTC Go to previous message
ETS35008
We are still working on better graphics for the manual, but for now this should be enough to help you assemble ETS35008.
index.php?t=getfile&id=40393&private=0
You can ignore 'step 8' because it has now been added to part G13b
index.php?t=getfile&id=40130&private=0
https://images3.sw-cdn.net/model/picture/674x501_1088833_2442583_1396016487.jpg
https://images4.sw-cdn.net/model/picture/674x501_1088833_2442584_1396016487.jpg
https://images3.sw-cdn.net/model/picture/674x501_1088833_2442585_1396016487.jpg
https://images1.sw-cdn.net/model/picture/674x501_1088833_2442586_1396016487.jpg
https://images2.sw-cdn.net/model/picture/674x501_1088833_2442587_1396016487.jpg
[Updated on: Fri, 28 March 2014 14:24 UTC]
Previous Topic:Differential gearbox assembly instructions
Next Topic:Bristol L5G ECW Bus
