Question about Bounding Box Limits
Question about Bounding Box Limits [message #69483] Sat, 08 June 2013 16:01 UTC Go to next message
avatar Mel_Miniatures  is currently offline Mel_Miniatures
Im trying to find this information on the site, on the materials gidelines and on the tutorials but I cant find it.
I have this model, http://www.shapeways.com/model/1143420/rikipeke02b.html very big and flat. It is inside the Bounding Box Limits. But for some reason, the moment I increase its height a little, the prize suddenly goes up extremely fast.
For example
http://www.shapeways.com/model/1143416/rikipeke02.html
Both models are the same, the only difference is one little stick and suddenly the price is over 70€ more. Why does this happen? Is there a Bounding Box Limit that increases the price?
Re: Question about Bounding Box Limits [message #69484 is a reply to message #69483 ] Sat, 08 June 2013 16:25 UTC Go to previous messageGo to next message
Maybe it's down to this:
Quote:
We also offer a volume and density discount on Strong & Flexible materials. For models that are greater than 10% dense (material volume divided by bounding box volume), after the first 20cm3, the remaining volume is calculated with a 50% discount.
What are the actual prices of your 2 models?
Which material?
Also go to the Model in Edit Mode and check out the Oriented Bounding Box data - this is what is used in the calcs.
Re: Question about Bounding Box Limits [message #69489 is a reply to message #69484 ] Sat, 08 June 2013 17:16 UTC Go to previous messageGo to next message
The first model costs
101,06 € (132$) in white strong flexible
Oriented Bounds (used for determining printability)
In:   13.6 w x 6.5 d x 0.4 h
Cm:   34.5 w x 16.4 d x 1.1 h
Vol: 133.02 cm³
The second model costs
174,7 € (227$) in white strong flexible
In:   13.6 w x 6.5 d x 1.4 h
Cm:   34.5 w x 16.4 d x 3.5 h
Vol: 133.06 cm³
Re: Question about Bounding Box Limits [message #69490 is a reply to message #69489 ] Sat, 08 June 2013 17:33 UTC Go to previous messageGo to next message
The spike makes your models print density lower than 10% therefore you don't get the discount.
Re: Question about Bounding Box Limits [message #69491 is a reply to message #69490 ] Sat, 08 June 2013 17:34 UTC Go to previous message
Indeed.
Thanks.
Previous Topic:Second Print run always a looser fit - same stl file, looser tolerances
Next Topic:Is it magnetic?
