Need to model a 4.5"widex4" deep cylidrical strainer
Need to model a 4.5"widex4" deep cylidrical strainer [message #69362] Fri, 07 June 2013 00:54 UTC Go to next message
avatar sgoeckner  is currently offline sgoeckner
I need a simple cylinder (I have dimensions but lack the skill to draw it) that has holes or mesh in the bottom of it.
The cylinder will be 4.5" wide and 4" deep. It will have a bottom with say 1mm holes or so. At the top, which is open, it will have a flange 1/10".
The object is shaped JUST like the strainer basket for a pool pump. It will sit inside a plastic jug whose opening is 4.72"
Thickness of the finished product is 1mm
Anybody up for the task?
Thickness can be a bit more or less. Important thing is the strainer on the bottom, and the lip at the top to keep from falling inside the opening of the plastic bottle it will sit in.
Re: Need to model a 4.5"widex4" deep cylidrical strainer [message #69459 is a reply to message #69362 ] Fri, 07 June 2013 22:31 UTC Go to previous message
http://tinyurl.com/qee67wt
http://tinyurl.com/q8kwf8j
It would be cheaper with holes around the sides.
[Updated on: Fri, 07 June 2013 22:39 UTC]
Previous Topic:jewelry designs
Next Topic:3D modeler needed - [ Face to Face in Bangalore, India]
