Extremely expensive models (what am I doing wrong?)
icon4.gif  Extremely expensive models (what am I doing wrong?) [message #68532] Thu, 23 May 2013 09:41 UTC Go to next message
avatar piratestef  is currently offline piratestef
the files Hi guys,
I'm working on two projects that include 3D printing and I'm running into some problems.
The models that I uploaded onto shapeways are with the cheapest option way to expensive. The tutorials on making the models cheaper (wall thickness and open models) appear to have no effect.
How do I get my products cheaper to produce? size? different shape?
I hope you guys can help me, the files are in the attachments.
Re: Extremely expensive models (what am I doing wrong?) [message #68539 is a reply to message #68532 ] Thu, 23 May 2013 12:35 UTC Go to previous messageGo to next message
What material are you thinking of?
What do you consider expensive?
Your models are, by Shapeways standards, huge. Most of the SW materials charge by volume (wsf = 1.4 USD per cm3), so the best way to get cheaper models is reduce the volume.
Re: Extremely expensive models (what am I doing wrong?) [message #68540 is a reply to message #68539 ] Thu, 23 May 2013 13:02 UTC Go to previous messageGo to next message
For the vaas they calculated around $1800 dollar
and for the Ralph they calculated 330 dollar
Re: Extremely expensive models (what am I doing wrong?) [message #68541 is a reply to message #68540 ] Thu, 23 May 2013 13:29 UTC Go to previous messageGo to next message
Unfortunately this sounds about right - if we take the "spherical cow" approach,
"Ralph" is a simple hollow cylinder with radius 14 and height 28, which at 1mm
wall thickness translates to a bit over 240 cm^3, or around $340.
A potential solution is to replace at least some of the solid surfaces with a mesh-like
structure - or simply make them smaller, as volume (and hence price) goes with the
third power.
Re: Extremely expensive models (what am I doing wrong?) [message #68542 is a reply to message #68540 ] Thu, 23 May 2013 13:38 UTC Go to previous messageGo to next message
The Ralph has a volume of 234cm3 so 234 * 1.4 = 327 USD . Plus the handling fee of 1.5 gives a total of 328.50 USD, so that is correct.
The vaas has problems: the 'cups' that you have cut the bottoms off and then stacked are not manifold. That is to say they are not watertight shells (in the sense of closed in volumes). The bottom edges of each needs to be added except for the bottom one where it is the inner face of thebottom that is missing. When SW's system encounters such models it tries to fix them and does not always get it as you might wish. In this case it has probably closed the holes and solidified the whole thing, giving a high volume and hence high price. Even if you fix it, it will be expensive. And if it is a vase, when printed in wsf it will not be watertight (in the holding a liquid sense) unless you post-process it
Re: Extremely expensive models (what am I doing wrong?) [message #68550 is a reply to message #68542 ] Thu, 23 May 2013 15:41 UTC Go to previous message
Thanks for all the info! I now have a better insight in how the system works.
thanks guys!
Previous Topic:help with transparent material
Next Topic:Steampunk Nautilus submarine
