37-sided die - can anyone hollow it out?
37-sided die - can anyone hollow it out? [message #68328] Sun, 19 May 2013 19:02 UTC Go to next message
avatar td3379  is currently offline td3379
As a dice collector, I loved finding this on Thingiverse: http://www.thingiverse.com/thing:58408
It's wonderfully customizable, allegedly allowing anyone to tweak it to design any sided-die they wish!
Only problem is, the model is solid, and as I discovered when I uploaded my model to Shapeways, it'd cost over $30 in alumide.
Can anyone hollow it out? I assume this would be a simple process? I wouldn't even know where to begin.
Anyway, here's my D37 (37-sided die) model: http://www.thingiverse.com/thing:83281
And here's a rendering of it:
http://thingiverse-production.s3.amazonaws.com/renders/be/6a/7b/05/28/ndie_20130503-17918-oecnr8-0_preview_featured.jpg
I'd love a hollowed STL file of my file. (After that, I'd be more than happy to upload it to my "store" with no price markup, since I can't take credit for creating the base model).
37 seemed like a wonderful random prime number to test it out... I'm curious to discover how it rolls!
[Updated on: Sun, 19 May 2013 19:13 UTC]
Re: 37-sided die - can anyone hollow it out? [message #68331 is a reply to message #68328 ] Sun, 19 May 2013 22:59 UTC Go to previous messageGo to next message
avatar Keymaker  is currently offline Keymaker
Shapeways Crew
if you want to hollow it out you need to decide where to put hole in to it. and dice with one hole will look wierd.
The only thing that limits us is our imagination.
Re: 37-sided die - can anyone hollow it out? [message #68332 is a reply to message #68331 ] Sun, 19 May 2013 23:05 UTC Go to previous messageGo to next message
Hm, is there any way to hollow out the center without adding a hole? The support material from Shapeways's 3-D printer would then just remain inside the object, I think?
Re: 37-sided die - can anyone hollow it out? [message #68341 is a reply to message #68332 ] Mon, 20 May 2013 07:43 UTC Go to previous messageGo to next message
Quote:
I guess this is more a technical issue, how much distance do I need to keep from the different parts of a model so they won't fuse together when 3D printed?
In theory you are correct. But what do we call a hollow object that's full of the same stuff as the shell is made of? Solid.
In practice if you upload a hollow shell with no holes then the SW software will treat your object as solid.
Wrt your specific model you could make many holes and make them a feature. I also note that in the render the numbers do not line up with the faces - is this not a problem? Also, how do you read the number that the die is showing?
Re: 37-sided die - can anyone hollow it out? [message #68345 is a reply to message #68341 ] Mon, 20 May 2013 10:56 UTC Go to previous messageGo to next message
avatar HenryAlfredo  is currently offline HenryAlfredo
many holes as a feature is a solution... you might also want to hollow out the model and create a very small escape hole to fool the software, you should advise the service team of your intentional trapping of the material, i don't know if it will still be allowed though.
peace
Marco
Re: 37-sided die - can anyone hollow it out? [message #68347 is a reply to message #68345 ] Mon, 20 May 2013 12:10 UTC Go to previous messageGo to next message
I believe this is allowed with FD/FUD but not other materials.
Re: 37-sided die - can anyone hollow it out? [message #68376 is a reply to message #68347 ] Mon, 20 May 2013 19:33 UTC Go to previous messageGo to next message
Thanks, everyone, for your ideas. I suppose I am under the impression that hollowing out the middle without means of escape is allowed... I own this 32-sided die model in purple strong & flexible: http://www.shapeways.com/model/187765/d32-sphere-dice.html
As it says in the description, the walls are only 1.5mm thick, but it is full of support material to keep it heavy. Could a similar approach be used on my design?
As for the fact that the numbers do not line up with the faces, that is actually intentional. Once the die has stopped rolling, a single number will be facing directly up, even though it may not be flat. This one works quite well: http://www.shapeways.com/model/250377/d15-sphere-dice.html
I'm very curious to see if this new Thingiverse model works just as well and rolls just as fairly Cool
Re: 37-sided die - can anyone hollow it out? [message #68472 is a reply to message #68376 ] Tue, 21 May 2013 23:14 UTC Go to previous message
Thanks again, Shapeways community, for your help. I now have a hollowed model of the D37 available for printing. Check it out here: http://www.shapeways.com/model/1109389/d37-die.html
...and download it if you wish.
Keep in mind that because of the way the Thingiverse Customizer worked (translation: bugs yet to work out), small portions of the numbers are not visible on the model, but no number is affected in such a way that it is unreadable.
If anyone would like to work on this model to restore the missing bits of the numbers, that would be lovely. I realize I am simply begging here, but you would have my gratitude, and probably some more of these sunglasses guys: Cool Cool Cool
Previous Topic:Looking for an experienced designer who can repair the attached STL file
Next Topic:need help designing pendant
