Spray paint on 3d printing object
Spray paint on 3d printing object [message #68160] Thu, 16 May 2013 15:29 UTC Go to next message
avatar TommyHewCk  is currently offline TommyHewCk
Can we spray painting with strong and flexible plastic?
Re: Spray paint on 3d printing object [message #68163 is a reply to message #68160 ] Thu, 16 May 2013 16:18 UTC Go to previous messageGo to next message
Absolutely, make sure you clean the part really well and plastic primer will let your paint stick better and will make the paint job look nicer for longer.
Re: Spray paint on 3d printing object [message #68180 is a reply to message #68160 ] Thu, 16 May 2013 23:34 UTC Go to previous messageGo to next message
I've had good results with spray dye, e.g. VHT vinyl spray dye. It soaks into the porous WSF, so it won't chip off.
Re: Spray paint on 3d printing object [message #68194 is a reply to message #68180 ] Fri, 17 May 2013 03:13 UTC Go to previous messageGo to next message
Thanks for that, I didn't know about this! I've added it to my personal list I maintain specifically for building stuff. Smile
Patterns For CNC
Re: Spray paint on 3d printing object [message #68334 is a reply to message #68194 ] Mon, 20 May 2013 02:54 UTC Go to previous messageGo to next message
avatar TinyMtn  is currently offline TinyMtn
Just make sure to use a water-based sealant/paint and not oil-based (they'll pit). Minwax Polycrylic works great for WSF parts, I've found.
Mark
tinymtn.com tinymtnbiz@gmail.com
Re: Spray paint on 3d printing object [message #68417 is a reply to message #68160 ] Tue, 21 May 2013 09:01 UTC Go to previous message
Tamiya Fine Surface Primer works well with WSF (and FUD), once a couple of coats have been applied the surface is good for Acrylics or enamels.
Spray Acrylic (Humbrol brand) works well straight onto WSF too. but generally needs 4 or 5 coats..
Previous Topic:Best/Easiest 3D Design Software
Next Topic:Shapeways - PLEASE add Argentium Silver to your line-up
