| [Rhino] export to STL [message #507] Sat, 02 August 2008 15:22 UTC |
Although the problems can be fixed, I wonder what they are. I get STL related errors at other sites as well.
I export with Rhino v2 and I can view the files in other programs without problem. Why aren't they usable by the printer by default?
An other question: is it possible to zoom in the 3D tool on this site?
[edit:]
from other thread:
So far, I've tried weld, but that does not make a difference as the STL is exactly the same
[Updated on: Sat, 02 August 2008 22:41 UTC]
| Re: [Rhino] export to STL [message #513 is a reply to message #507 ] Sun, 03 August 2008 03:28 UTC |
I only had a problem with Rhino to STL because the model was too big, as STL is interpreted in meters (which meant my model was tens of meters long). When you create a new model, choose "Millimeters" for your scale and then Scale 3D typing .01 at the prompt. Then export.
| Re: [Rhino] export to STL [message #517 is a reply to message #513 ] Sun, 03 August 2008 09:24 UTC |
| Sovereign wrote on Sat, 02 August 2008 23:28 | I only had a problem with Rhino to STL because the model was too big, as STL is interpreted in meters (which meant my model was tens of meters long). When you create a new model, choose "Millimeters" for your scale and then Scale 3D typing .01 at the prompt. Then export.
True. But There was a mail telling me that they've made it "printable". I wonder what they have done.
I think you mean 0.001
| Re: [Rhino] export to STL [message #552 is a reply to message #507 ] Mon, 04 August 2008 04:37 UTC |
Done that, still doesn't work. I'm using Rhino v4 and so far Shapeways is the only bureau that has problems with the files.
| Re: [Rhino] export to STL [message #680 is a reply to message #507 ] Wed, 06 August 2008 23:48 UTC |
I'm brand new to Shapeways. Long a fan of Rhino (since version 1) I am very curious to know how this turns out.
-Douglas
