Key Needed
Key Needed [message #67753] Fri, 10 May 2013 04:48 UTC Go to next message
avatar mehrdada  is currently offline mehrdada
Hello everybody!
I need a exact copy of my key made. I can even send the key to you if it helps make it a better 3D model. If the first one turns out good, I will pay you again for another key that is the type of key.
I've attached some photos to the type of key it is but its not the actual key. The key is the same brand and same model. Just want to figure out if its possible. Thanks
I forgot to mention I will pay anywhere from $50-$100 per key model.
Thanks.
[Updated on: Fri, 10 May 2013 05:25 UTC]
Re: Key Needed [message #67790 is a reply to message #67753 ] Fri, 10 May 2013 17:17 UTC Go to previous messageGo to next message
avatar CADNinja  is currently offline CADNinja
Why dont you just go to the hardware store to get a copy made??
Otherwise this would need to be scanned in and that alone would be over $100
Re: Key Needed [message #67797 is a reply to message #67790 ] Fri, 10 May 2013 18:33 UTC Go to previous messageGo to next message
Rather obviously, the "Do Not Duplicate" would scare off most designers.
Beyond that, if you want a functional key, I'm not sure that the Stainless Steel material would be precise enough to work properly.
Re: Key Needed [message #67807 is a reply to message #67797 ] Sat, 11 May 2013 01:22 UTC Go to previous message
Ah... Did not see that. Entire posting and threads should be removed
Previous Topic:Eyeglasses Ear Piece
Next Topic:3D model Train coaches in need of help / assistance. OO / 4mm scale
