Size problem
Size problem [message #67590] Tue, 07 May 2013 18:14 UTC Go to next message
avatar markwgray  is currently offline markwgray
I've been looking through the forums and can't find this problem addressed.
I am building in Lightwave, exporting Collada, saving an STL in Meshlab, and my object keeps coming up much smaller on Shapeways (and it says it was scaled when uploaded).
Ideas?
Thanks for any help.
Mark
Re: Size problem [message #67593 is a reply to message #67590 ] Tue, 07 May 2013 19:30 UTC Go to previous messageGo to next message
Can you share the file? What size is it supposed to be/what size is it coming up as? Can you also make the item public and share the link so we can see?
Re: Size problem [message #67595 is a reply to message #67593 ] Tue, 07 May 2013 19:36 UTC Go to previous messageGo to next message
I took it into netfabb and scaled it by 1000 and it appears to be the proper size now. I had seen somewhere else that perhaps Lightwave needed to be scaled up by 1000, but it didn't work scaling it up by 1000 in the program itself.
Thanks for your help. I'll see if this works as a workflow workaround.
Re: Size problem [message #67629 is a reply to message #67590 ] Wed, 08 May 2013 14:00 UTC Go to previous message
avatar adminsmithee  is currently offline adminsmithee
Make sure when you export and import you keep the same conversion. for example export in meters and upload as meters.
i had the same issue when i started out
Edit: fixed the word "upload"
[Updated on: Wed, 08 May 2013 14:51 UTC] by Moderator
Previous Topic:3D Printing a lacrosse head
Next Topic:Looking for a website with 3D Food design layouts
