Home » Community » It arrived! » My First print arrived !!
My First print arrived !! [message #66328] Thu, 18 April 2013 10:00 UTC Go to next message
avatar Lantansia  is currently offline Lantansia
This is my first time using Shapeways service.
The print is finished nicely Laughing
index.php?t=getfile&id=30761&private=0
It come with three prices. Need some work to assemble it with proxy glue.
Enjoy.
index.php?t=getfile&id=30757&private=0
index.php?t=getfile&id=30758&private=0
index.php?t=getfile&id=30759&private=0
index.php?t=getfile&id=30760&private=0
Re: My First print arrived !! [message #66379 is a reply to message #66328 ] Thu, 18 April 2013 20:24 UTC Go to previous messageGo to next message
avatar Steve_Storm  is currently offline Steve_Storm
Very nice work!
Re: My First print arrived !! [message #66394 is a reply to message #66328 ] Fri, 19 April 2013 02:41 UTC Go to previous messageGo to next message
avatar philnolan3d  is currently offline philnolan3d
That's great! Good idea making it in pieces too.
Re: My First print arrived !! [message #66443 is a reply to message #66394 ] Fri, 19 April 2013 15:57 UTC Go to previous messageGo to next message
Excellent job. Did you make it in separate pieces for easy customization or because of printing size?
Re: My First print arrived !! [message #66479 is a reply to message #66443 ] Fri, 19 April 2013 22:50 UTC Go to previous messageGo to next message
I make it seperate to reduce the weight of her head Very Happy
Her neck is weak. I join her small braids to her right shoulder make two supporting points of the whole head.
Also, it reduce volume hence reduce cost Laughing
Re: My First print arrived !! [message #66481 is a reply to message #66328 ] Fri, 19 April 2013 22:59 UTC Go to previous messageGo to next message
Very good idea. Is the volume reduced because you could hollow it out when model was separated, whereas you couldn't when it was one piece?
Re: My First print arrived !! [message #66562 is a reply to message #66481 ] Sun, 21 April 2013 03:10 UTC Go to previous messageGo to next message
You are Right Razz
Separate the a large piece make it easier to hollow. Especially shape that not easy to make escape holes.
Re: My First print arrived !! [message #67387 is a reply to message #66328 ] Fri, 03 May 2013 12:23 UTC Go to previous messageGo to next message
avatar karims  is currently offline karims
How did you get the colors done?
Does 3D print, if you give colored model, they will color it accordingly? I am new to all this, so I am trying to know.
Re: My First print arrived !! [message #67389 is a reply to message #67387 ] Fri, 03 May 2013 13:05 UTC Go to previous messageGo to next message
@karims - Currently, Full Color Sandstone is the only material that supports full color in printing. You can read about it here: http://www.shapeways.com/materials/sandstone
Re: My First print arrived !! [message #67424 is a reply to message #66328 ] Sat, 04 May 2013 03:21 UTC Go to previous message
Yes, it is fullcolor sandstone. You can apply a texture to the model and paint it as you want Razz
You can shade you model on the texture, so the model would have more depth and better look.
Previous Topic:Spider Gear by BRAM & OSKAR
Next Topic:Bulldog Keychain
