Portal 2 - Pressure button cup coaster
Portal 2 - Pressure button cup coaster [message #67044] Mon, 29 April 2013 09:40 UTC Go to next message
avatar Psychobob  is currently offline Psychobob
I've previously posted about this, but it was more in the context of a misprint. Since then Shapeways has sent a reprint and all is good!
Below is a FCS print I've made with the intention of using it as a cup coaster. I would have liked to use ceramic for the part where the cup touches the surface, but unfortunately it doesn't look like there's a red option on the ceramic materials and I didn't have the correct bits to glaze it myself.
This is my first experience in printing in FCS and I must say, I'm pleasantly surprised. The piece feels pretty sturdy and colours look great. The surface finish was a bit rough, but I've had some great success in smoothing it out.
Using some fine sandpaper I gave the piece a quick sand and then a couple of light coats of clear coat. Once finished the surface finish was very smooth to the touch and looked even better than before. I've been using mine for 3 weeks now at the office and it seems to be holding up really well, barely any marks on it even though I go through 5 cups each day
If you look at my youtube video (watch in HD to see the detail), 0:05-01:20 is footage of the original piece straight out of the box, and then everything after it is the piece once it has been sanded and clear coated.
Time to get on with the next project!
Youtube video: http://www.youtube.com/watch?v=1l0h75KTVTI
Shapeways shop: http://www.shapeways.com/shops/PsychobobArts
My website: http://www.psychobob.co.uk/2013/04/3d-print-portal-pressurep late.html
http://1.bp.blogspot.com/-oTOv2JCJucE/UX1ByEJpFQI/AAAAAAAAAjM/nzHp67n30hA/s1600/DSC_8244.jpg
Original piece straight out of the box
http://1.bp.blogspot.com/-46PSMn7qvms/UX1ByKafaTI/AAAAAAAAAjI/pigiKdX6lVs/s1600/DSC_8311.jpg
After a sanding and clear coat
http://3.bp.blogspot.com/-GBJNyzrtT7c/UX1BywjCdDI/AAAAAAAAAjU/UIXCWF0UxYw/s1600/DSC_8330.jpg
Standard coke can shot for scale reference
[Updated on: Mon, 29 April 2013 10:20 UTC]
Check out my blog on my 3D print projects:
And here's my Shapeways shop!
Re: Portal 2 - Pressure button cup coaster [message #67045 is a reply to message #67044 ] Mon, 29 April 2013 09:57 UTC Go to previous messageGo to next message
avatar MitchellJetten is currently online MitchellJetten
Amazing!
Very cool Cool
Like all of your work Very Happy
Customer Service Coordinator
Shapeways
Re: Portal 2 - Pressure button cup coaster [message #67195 is a reply to message #67045 ] Tue, 30 April 2013 21:05 UTC Go to previous messageGo to next message
Much obliged Mitchell, much obliged!
Re: Portal 2 - Pressure button cup coaster [message #67251 is a reply to message #67044 ] Wed, 01 May 2013 14:17 UTC Go to previous messageGo to next message
avatar trishycakes  is currently offline trishycakes
This is a great model and the finishing/sealing looks really good.
Re: Portal 2 - Pressure button cup coaster [message #67535 is a reply to message #67044 ] Mon, 06 May 2013 14:55 UTC Go to previous messageGo to next message
Looks great. Could I ask you to post some details on the posting and clear coating? I've only ever tried sanding one FCS piece (with a Dremel) and the surface kind of got a build up of wax on it which then solidified into a semi opaque state. Was not good at all.
Re: Portal 2 - Pressure button cup coaster [message #67626 is a reply to message #67535 ] Wed, 08 May 2013 13:17 UTC Go to previous messageGo to next message
Thanks everyone for taking the time to look at my print Smile
@Lensman:
No problem. I've seen some people using those abrasive brushes and they seem to get really good results. I've personally never tried it, but I think I will give it a go as it should be a lot quicker than sanding by hand like I did, and you'll probably be able to smooth out the small or awkward parts much better.
I just took some 400 grit sand paper and gave it a quick light sand by hand. When sanding it did produce a lot of white powder residue (from the CA solution they dip the piece into I believe). Some comes off, but a lot sticks to the piece making it look fairly misty/snowy that you won't be able to remove (so the same semi-opaque finish you experienced I think). I think this is because using sandpaper grinds it into the surface. Using a dremel abrasive brush may or may not do this as it's not really grinding into the surface like sandpaper does. It looks horrible at this stage, but once I then put a clear coat over the top of it, it fixes this. As soon as the clear coat touches it, it will remove the misting/snowy effect and the colours will go back to normal. This process is then repeated once or twice once the clear coat has fully dried.
Another user is much more experienced in smoothing FCS than me, and he uses a Dremel too, so it's well worth looking at his process (his name is "Kaetemi" and below is a link to a thread he has posted some information on. Scroll down from this post and you'll see more information)
http://www.shapeways.com/forum/index.php?t=msg&&th=7 191&goto=43493#msg_43493
Re: Portal 2 - Pressure button cup coaster [message #67630 is a reply to message #67044 ] Wed, 08 May 2013 14:05 UTC Go to previous message
Thanks for that. Maybe it's the Dremel that's superheating it making even more of a mess. I'll check outt the link.
Previous Topic:3D printed G-Shock part 2
Next Topic:Danger Cube by OSKAR
