Uh oh! Seems like your model needs a bit more love before our robots can work their magic.
Uh oh! Seems like your model needs a bit more love before our robots can work their magic. [message #66761] Wed, 24 April 2013 05:16 UTC Go to next message
avatar andrew40  is currently offline andrew40
Hello
I received an email saying that "There's a problem with your model". However, there was no description of what the problem was, such as non-manifold edges. If I did not get a specific error message, does this mean there is a problem with the file type?
Please let me know if anyone else has had this issue. Thank you
Re: Uh oh! Seems like your model needs a bit more love before our robots can work their magic. [message #66765 is a reply to message #66761 ] Wed, 24 April 2013 05:48 UTC Go to previous messageGo to next message
See here 66133 and search the forum for many other instances.
Re: Uh oh! Seems like your model needs a bit more love before our robots can work their magic. [message #66767 is a reply to message #66765 ] Wed, 24 April 2013 06:04 UTC Go to previous messageGo to next message
Shapeways Crew
Last time I got this e-mail I think (but I am not 100% sure) that it was because I exceeded the 1 million triangles limit. If it was the case, having a more explicit message would have helped.
Re: Uh oh! Seems like your model needs a bit more love before our robots can work their magic. [message #66798 is a reply to message #66761 ] Wed, 24 April 2013 13:18 UTC Go to previous messageGo to next message
Can you share the model with us? Currently, if you fail the automatic checks, it just kicks back a failure error Sad. If it were a file type error, or manifold error, you would be notified.
Re: Uh oh! Seems like your model needs a bit more love before our robots can work their magic. [message #66799 is a reply to message #66761 ] Wed, 24 April 2013 13:20 UTC Go to previous messageGo to next message
I think everyone gets that message at some point.
Did they not give you an image of where the problem is?
I will look at it for you; just upload the file. By PM or my email, if you want to keep it private.
Re: Uh oh! Seems like your model needs a bit more love before our robots can work their magic. [message #66800 is a reply to message #66799 ] Wed, 24 April 2013 13:24 UTC Go to previous messageGo to next message
JACANT wrote on Wed, 24 April 2013 13:20
Images of the problem area are only for manual check rejections that are after you order.
Re: Uh oh! Seems like your model needs a bit more love before our robots can work their magic. [message #66807 is a reply to message #66800 ] Wed, 24 April 2013 14:51 UTC Go to previous messageGo to next message
avatar trishycakes  is currently offline trishycakes
I have been having that problem off and on myself, but only if I run it through netfabb. If I try it again, sometimes it just works. I have been avoiding netfabb at the moment for that exact reason.
Re: Uh oh! Seems like your model needs a bit more love before our robots can work their magic. [message #66822 is a reply to message #66761 ] Wed, 24 April 2013 22:14 UTC Go to previous message
That error message occurs due to one of several factors including (but not limited to);
Over 1 million triangles. (save the file as a stl binary, if the model is 49.6MB+ there's more than 1million triangles. or just use NetFabb to get the count)
A time-out on Shapeways Mesh Medic checking software generally caused by a close to 1m tri limit colour model or complicated multi shell model (e.g. chain maille)
A winding check error - this is to do with a model having triangles that are not in the right order and probably just one doesn't match up with the rest.
Models that are built using a face to face butting up system (Sketchup?) will also cause a similar issue if the amount of shared faces causes confusion with Mesh Medic.
Previous Topic:Wall thickness of a surface
Next Topic:Weekend Contest #9: Curate our Homepage - the Best of 3D Printing
