Home » Community » Work in progress » Problem with Model
Problem with Model [message #66686] Tue, 23 April 2013 07:22 UTC Go to next message
avatar mphatak  is currently offline mphatak
Seems to be a problem with this model....
....but have no clue where to start looking....
any advice?
Re: Problem with Model [message #66687 is a reply to message #66686 ] Tue, 23 April 2013 07:40 UTC Go to previous messageGo to next message
First Check:
Accutrans tells me the model is watertight...
Re: Problem with Model [message #66689 is a reply to message #66687 ] Tue, 23 April 2013 07:49 UTC Go to previous messageGo to next message
Saved the file as .dae with the 'Quads' flag unchecked and now it has imported....
No idea what any of this means, but I hope this helps someone else with a similar problem....
Re: Problem with Model [message #66696 is a reply to message #66686 ] Tue, 23 April 2013 09:18 UTC Go to previous messageGo to next message
The problem is, you have lines on the faces between the three small openings on both sides, that are not required.
They are creating faces on top of faces. Which confuses Shapeways software.
They will show up in Netfabb as blue and red stripes.
Delete all extra lines
[Updated on: Tue, 23 April 2013 09:34 UTC]
jacantdesign@gmail.com
Re: Problem with Model [message #66706 is a reply to message #66696 ] Tue, 23 April 2013 09:36 UTC Go to previous messageGo to next message
this is strange, I do not see any such lines
what I did was to import it into Accutrans and that seemed to fix it....
thx for looking into this anyway.
I will bear your suggestion in mind for future variations...
Re: Problem with Model [message #66709 is a reply to message #66706 ] Tue, 23 April 2013 09:49 UTC Go to previous messageGo to next message
I don't know what software you used to create the model. I imported the DAE into Sketchup. Here is a screenshot
If you did use Sketchup. It would be wise to export as STL, instead of DAE.
index.php?t=getfile&id=31028&private=0
  • Attachment: image.png
    (Size: 10.30KB, Downloaded 157 time(s))
Re: Problem with Model [message #66710 is a reply to message #66709 ] Tue, 23 April 2013 09:51 UTC Go to previous messageGo to next message
that is odd. I am also using SketchUp. Here is a screenshot of what I see...
index.php?t=getfile&id=31029&private=0
Re: Problem with Model [message #66740 is a reply to message #66686 ] Tue, 23 April 2013 21:10 UTC Go to previous messageGo to next message
avatar InnerbreedFX  is currently offline InnerbreedFX
This is what i see...your model is open with no sides...
index.php?t=getfile&id=31048&private=0
give me a few mins ill fix this....
  • Attachment: Capture.JPG
    (Size: 60.92KB, Downloaded 130 time(s))
Innerbreed.co.uk
Create - Innovate - Inspire
Re: Problem with Model [message #66742 is a reply to message #66740 ] Tue, 23 April 2013 21:23 UTC Go to previous messageGo to next message
Ok i have closed the model but it seems rather small on my view port.
how big is it supposed to be?
the image is of your part next to a "1MM CUBE" !!! Sad
http://i531.photobucket.com/albums/dd355/innerbreed/Capture2-6.jpg
  • Attachment: untitled.stl
    (Size: 24.98KB, Downloaded 18 time(s))
[Updated on: Tue, 23 April 2013 21:24 UTC]
Innerbreed.co.uk
Re: Problem with Model [message #66743 is a reply to message #66742 ] Tue, 23 April 2013 21:42 UTC Go to previous messageGo to next message
@innerbreed. Just scale by 25.4 It is 1.5mm thick
I think the answer to the visibility of the extra lines in Sketchup is when the model is exploded.
View - Edge style - Edges - Ticked. Shows the lines. Un-Ticked hides them
That is when Profiles are ticked
Here is that link to export as STL. You will have less problems than exporting as a DAE.
https://github.com/SketchUp/sketchup-stl
[Updated on: Tue, 23 April 2013 21:55 UTC]
Re: Problem with Model [message #66744 is a reply to message #66743 ] Tue, 23 April 2013 21:47 UTC Go to previous message
scaled by 25.4.
    (Size: 24.98KB, Downloaded 14 time(s))
Innerbreed.co.uk
Previous Topic:Enclosure + Lid
Next Topic:Problem uploading model :(
