Home » Support » 3D Design »
My flute model isn't quite hollow
My flute model isn't quite hollow [message #66480] Fri, 19 April 2013 22:56 UTC Go to next message
avatar wbajzek  is currently offline wbajzek
I made a model of a simple flute (fife, actually). and ordered a print in white strong&flexible. It came with a plug of material about 2" long about halfway through the bore, between the finger holes and mouth hole, so it doesn't actually work. I just checked my file again and it looks fine to me. Any idea why this would happen? That was a rather expensive mistake Sad
[Updated on: Sat, 20 April 2013 02:01 UTC]
Re: My flute model isn't quite hollow [message #66483 is a reply to message #66480 ] Fri, 19 April 2013 23:22 UTC Go to previous messageGo to next message
Are you sure that the blockage is solid?
It could just be 'loose' powder that is stuck in there.
Try pushing on it with a rod or stick.
Re: My flute model isn't quite hollow [message #66486 is a reply to message #66483 ] Sat, 20 April 2013 00:26 UTC Go to previous messageGo to next message
I tried... It's pretty solid, but also powdery. Maybe I can punch through if I'm persistent. Thanks for checking it for me.
Re: My flute model isn't quite hollow [message #66489 is a reply to message #66483 ] Sat, 20 April 2013 00:53 UTC Go to previous messageGo to next message
That was it. I punched through and now it works. Thanks!
Re: My flute model isn't quite hollow [message #66495 is a reply to message #66489 ] Sat, 20 April 2013 04:37 UTC Go to previous messageGo to next message
Congrats.. Now, let us hear it... Smile
Re: My flute model isn't quite hollow [message #66544 is a reply to message #66495 ] Sat, 20 April 2013 19:12 UTC Go to previous messageGo to next message
stonysmith wrote on Sat, 20 April 2013 04:37
Here you go. Caveat; I play irish flute but don't really know about how to play a fife properly. I want to make a 3D printed copy of a 200-year old flute that I own, but it would cost so over $200 to print so I modeled this fife based on a known design from a book so I could try something much smaller and cheaper first. I wanted to be sure that the texture of the material wouldn't prevent the instrument from functioning properly.
I made a recording last night but it didn't sound as good. I decided it was probably because of the texture of the surface making it hard to get a good seal on the fingerholes, so I sanded the outside with 500 grit sandpaper and it made a big improvement.
  • Attachment: 3DFife.m4a
    (Size: 1.49MB, Downloaded 62 time(s))
Re: My flute model isn't quite hollow [message #66548 is a reply to message #66544 ] Sat, 20 April 2013 19:30 UTC Go to previous messageGo to next message
Very nice.
Just be aware that WSF is very porous. So be careful of the build up of saliva. You may need to seal it.
Have a look on post production techniques. http://www.shapeways.com/forum/index.php?t=thread&frm_id =95&
Re: My flute model isn't quite hollow [message #66793 is a reply to message #66544 ] Wed, 24 April 2013 12:27 UTC Go to previous messageGo to next message
avatar rosethun@yahoo.com  is currently offline rosethun@yahoo.com
Oh, it is beautiful! thanks for sharing.
Re: My flute model isn't quite hollow [message #70093 is a reply to message #66480 ] Wed, 19 June 2013 12:36 UTC Go to previous message
Sounds good... now can we SEE it?
I recently modeled an Ocarina for printing in ceramic but it was ridiculously expensive. Too bad. Maybe I can make it thinner and print in WSF.
Previous Topic:It looks like my model has been sealed at either end.
Next Topic:Mechanical design of springs incorporated into object
