Home » Support » 3D Design » Setting "scale" when uploading?
Setting "scale" when uploading? [message #6583] Wed, 16 September 2009 01:40 UTC Go to next message
avatar andykalin  is currently offline andykalin
Hi All,
I'm a newbie uploading my first model (an STL exported from topmod). When I select "inches" from the Scale choices on the upload page, my model is too big (over 17cm long), but when I select "millimeters", it is too small (0.7 cm long).
Is there any way to specify the exact dimensions I want, when exporting or upload? Not sure how to do that ...
Andy
Re: Setting "scale" when uploading? [message #6584 is a reply to message #6583 ] Wed, 16 September 2009 02:04 UTC Go to previous messageGo to next message
avatar groovelock  is currently offline groovelock
You can load your model into "MeshLab'.
On the Mac version, select the Filters Menu -> Normals, Curvature, and Orientation -> Apply Transform. Select "Scale" and check "Uniform". Resize as desired. Click "Close and Freeze", and then export the model.
There is a useful calculator here to get the size correct for the desired amount you want to pay.
http://www.shapeways.com/blog/archives/36-Resize,-Get-the-Ri ght-Price.html
[Updated on: Wed, 16 September 2009 02:18 UTC]
Re: Setting "scale" when uploading? [message #6585 is a reply to message #6584 ] Wed, 16 September 2009 02:34 UTC Go to previous message
thanks!
Previous Topic:Coil Spring Test Data
Next Topic:non-manifold error checking?
