Possible to... with Stainless Steel
Possible to... with Stainless Steel [message #65561] Fri, 05 April 2013 19:59 UTC Go to next message
avatar S_Till  is currently offline S_Till
Hi!
I haven´t ordered my jewlery model j
yet, because there are some questions before...
1st of all: is it possible for a jeweler here in town to insert gemstones into the steel model?
2nd: is it possible to make the steel model black? (with lineoil and heat)? (sure before inserting the gemstones)...
Why doesn´t accept shapeways my design made with SketchUp8?
Thank you so far...
Yours
S_Till
Re: Possible to... with Stainless Steel [message #65606 is a reply to message #65561 ] Sat, 06 April 2013 05:21 UTC Go to previous messageGo to next message
For a jeweler to insert stones you will need to make recesses in your design that except the stones. Also too, stones are usually held in place by metal prongs that bend over and secure the stones.
I don't know what lineoil is. Can you be more specific? There are numerous patinas that can be experimented with to alter the color, see Caswell Plating for starters. Keep in mind though that it is not 100% stainless steel, but rather a mixture of stainless steel and bronze. So when doing any kind of chemical reactions you need to realize that you'll be working with two completely different alloys bound together as one.
There are numerous reasons why you would get a Sketchup rejection. Can you send us the file? Or is it something you want to keep private. If don't mind people having it for personal use then upload it here as an attachment and someone from the forum will take a look at it and show you what's wrong.
Patterns For CNC
Re: Possible to... with Stainless Steel [message #65659 is a reply to message #65606 ] Sun, 07 April 2013 07:21 UTC Go to previous messageGo to next message
Dear James,
i´ts this item: (Version is older - including the gemstones)
http://sketchup.google.com/3dwarehouse/details?mid=55310920c6aa11d963b54e167a2a2f43&prevstart=0
[url= http://sketchup.google.com/3dwarehouse/details?mid=55310920c 6aa11d963b54e167a2a2f43&prevstart=0[/url]
For upload to shapeways I´ve converted it into .dae
There are moulds for the cabochon-cutted gemstones at the front of the fotoframe part and a little under...
"lineoil" is some natural oil that you can use to make steel black. you put it on an heat it up to 400°C. While burning anway it makes some chemical reaction with the metal (usualy used to protect iron not to get rusty) - lineoil is also a typical indrigent for oilcolour. That´s the german Name for it - maybee it´s called different in english... Embarassed
Thank You
S_Till
[Updated on: Sun, 07 April 2013 07:23 UTC]
Re: Possible to... with Stainless Steel [message #65671 is a reply to message #65561 ] Sun, 07 April 2013 12:28 UTC Go to previous messageGo to next message
S_Till wrote on Fri, 05 April 2013 19:59
Hi!
1/ Possible but it is difficult and it will be hard to fins anyone with experience of having done it.
2/ Yes, but it will eventually wear off.
Bill Bedford
Re: Possible to... with Stainless Steel [message #65675 is a reply to message #65659 ] Sun, 07 April 2013 13:46 UTC Go to previous messageGo to next message
Nice design!
I wasn't able to download it from the Trimble Warehouse and I don't see a link to your DAE file. I was however able to see the 3D view on Trimble. From this view I can tell you that you may have a problem with thin walls. What are the basic dimensions of this item? Also, you'll want to make sure you have proper clearance on that hinge if you want to 3D print it in situ. If you don't have proper clearance it will be welded together.
Take a look at these design rules for Shapeways' stainless steel.
As for lineoil I can't find any information about it other than it is an oil known about in Europe. That's ok though because I know what process you are talking about. Yeah, as Bill stated it's going to wear off eventually, but only from the high spots so that may look good depending on the starting color of the stainless steel / bronze.
The steel/bronze may be hard to bend over the edges of the stones so you may need to use epoxy or if you're going to use star sapphire as stated in the Trimble Warehouse description you can probably solder the stones in place being that star sapphire can withstand extremely high temperatures. The blackened base with blue star sapphire will look great!
The English translation for what you're making is called a locket.
Patterns For CNC
Re: Possible to... with Stainless Steel [message #65676 is a reply to message #65675 ] Sun, 07 April 2013 16:23 UTC Go to previous messageGo to next message
Hallo again!
I´d like the item to be massive. It´s dimensions are: height 9cm (if closed), width 9cm, deepth round about 2,5cm...
For inserting the cabochon gemstones: I´ll ask the jeweler who made the wedding rings of my best girl... Wink (stainless-steel-rings)
I only have to figure out, how to close the fotoframe-part at the top... maybe magnetic?
If the black colour weares of that´s no Problem - als long as it isn´t silver... Wink
Re: Possible to... with Stainless Steel [message #65679 is a reply to message #65676 ] Sun, 07 April 2013 16:32 UTC Go to previous messageGo to next message
Yeah a magnet would work great! Like one of these tiny nickel iron boron magnets. You'd just make a recess for in the design and then glue it in place.
EDIT: neodymium, not nickel. Probably nickle plated though. Razz
[Updated on: Sun, 07 April 2013 16:51 UTC]
Patterns For CNC
Re: Possible to... with Stainless Steel [message #65681 is a reply to message #65679 ] Sun, 07 April 2013 16:54 UTC Go to previous messageGo to next message
Dear James!
That are the ones i´ve been thingink of... Wink
I´ll work over...
Re: Possible to... with Stainless Steel [message #65685 is a reply to message #65681 ] Sun, 07 April 2013 17:37 UTC Go to previous messageGo to next message
Are you going to print the lid/cover of the piece separately? How will you manage the hinge?
Re: Possible to... with Stainless Steel [message #65686 is a reply to message #65685 ] Sun, 07 April 2013 17:47 UTC Go to previous message
Good point! I missed that! Very Happy
I keep getting the process confused with direct metal laser sintering. Razz
Yeah, you cannot 3D print that in Shapeways stainless steel in situ. You'll need to print the hinge separate from the main structure and then assemble it. Smile
Patterns For CNC
Previous Topic:Cleaning a Greasy Smudge off Black Strong and Flexible (Unpolished)
Next Topic:Vvapor treating
