Personalized Option?
Personalized Option? [message #65326] Mon, 01 April 2013 21:42 UTC Go to next message
avatar GarySG  is currently offline GarySG
I've seen a lot of products that instead of a 'buy' option, are replaced with a 'personalized' option, for engraving names and such. I'm curious how to set up one of my products in that way? Thanks Very Happy
"Hm, I'm so hungry I could eat an entire cow. Gerard, fire up the printer!"
Re: Personalized Option? [message #65329 is a reply to message #65326 ] Mon, 01 April 2013 23:14 UTC Go to previous messageGo to next message
I'm not completely sure myself since I haven't actually done it, but I think you get started by going to the edit mode for the model you want add customization to and then scroll down to the bottom of the page and select the Make this model a Co-Creator link.
Someone who has actually done it would probably have better instructions.
Patterns For CNC
Re: Personalized Option? [message #65343 is a reply to message #65326 ] Tue, 02 April 2013 12:39 UTC Go to previous messageGo to next message
You are correct James. We're going to set up a better refresher on Co-creators, but the short is. You can make any item you upload a co-creator. You set up to 3 different personalized variables. For example, if your item is a ring, one variable can be for the customer to pick a ring size. You also set the Max volume of your item. So ring example again, you want to use the largest size you make available so that when you create the customized item you don't go over the volume you specified (it will default to the volume of the model you uploaded). Once you publish your Co-Creator, you wait for someone to order. Once they order, you'll get an email about having a model to create. Follow the link and you will see the variables that the customer set, and then you design their item to their specifications.
Re: Personalized Option? [message #65356 is a reply to message #65343 ] Tue, 02 April 2013 15:09 UTC Go to previous messageGo to next message
Are there specified rules as to how long you can take to submit their personalized design? like, 24, 48 hours or anything like that? thanks for all the info Very Happy
Re: Personalized Option? [message #65357 is a reply to message #65356 ] Tue, 02 April 2013 15:12 UTC Go to previous messageGo to next message
Oh, and how does the pricing work? Is the customer charged the price only after I have submitted their personalized design so they pay for the exact volume? Because with the design I'm thinking about, the volume can differ quite a lot.
Re: Personalized Option? [message #65358 is a reply to message #65326 ] Tue, 02 April 2013 15:23 UTC Go to previous messageGo to next message
You specify in your setup how long you expect to take to submit a design.
The purchaser pays upfront. They are charged for the max volume that you entered, plus your markup. If your item ends up being less volume, neither you nor your customer gets the difference (no refund for unused volume, you get your markup only).
[Updated on: Tue, 02 April 2013 15:23 UTC]
Re: Personalized Option? [message #65366 is a reply to message #65358 ] Tue, 02 April 2013 17:22 UTC Go to previous messageGo to next message
avatar FabMeJewelry  is currently offline FabMeJewelry
Shapeways Crew
Just curious - What happens when the volume ends up a bit bigger than the designer stated ?
Wesley Günter - FabMeJewelry.com - Set a course, for the future ! *back on the forums ! x)
Re: Personalized Option? [message #65367 is a reply to message #65326 ] Tue, 02 April 2013 17:24 UTC Go to previous message
If the volume of the uploaded model exceeds the volume you specified, than it will be kicked back to you to redesign.
Previous Topic:New to design. What is the best software to design a up to scale object like my house.
Next Topic:Why can't I put the parts into one .STL?
