iPhone case dimensions
iPhone case dimensions [message #64928] Tue, 26 March 2013 18:39 UTC Go to next message
avatar Duggan  is currently offline Duggan
Hi!
Im making an iPhone case and I've been looking at a few here on Shapeways and I saw that some people were mixing up the depth and the height.
For example, one case was made with the dimensions: cm: 8.446 w x 1.384 d x 11.898 h and another was made with cm: 8.446 w x 11.816 d x 1.142 h. What should the depth be? A high number or a low number?
Thank you!
Re: iPhone case dimensions [message #64935 is a reply to message #64928 ] Tue, 26 March 2013 20:21 UTC Go to previous messageGo to next message
It doesn't matter. All that means is that the model is rotated one direction over another.
Since the parts are printed in pretty much random orientation, the specific choices you setup for your model won't affect printability.
Re: iPhone case dimensions [message #65620 is a reply to message #64928 ] Sat, 06 April 2013 12:16 UTC Go to previous message
avatar MatarazzoDesigns  is currently offline MatarazzoDesigns
If you are still having trouble figuring out the case dimensions, I suggest downloading this template file and checking your model against it.
Hope this helps.
Previous Topic:Best way to layout my model in Solidworks?
Next Topic:Shapeways says I need a greater distance or it will look ugly.
