Home » Support » 3D Design »
Best way to design a hexagon with increasing angles on sides?
Best way to design a hexagon with increasing angles on sides? [message #64392] Mon, 18 March 2013 22:48 UTC Go to next message
avatar prismspecs  is currently offline prismspecs
I want to create a 3d hexagon with a bit of a twist. The top face is exactly a hexagon, but each side has an angle starting at.. let's say 170degree (flaring out at the bottom. So 180 here is straight down). So the first of the six sides is 170, the 2nd is 167, the 3rd is 164 and so on. I realize that there must be an additional plane connecting the side faces to maintain a flat angle on all sides. Any ideas on how I might accomplish this one?
Re: Best way to design a hexagon with increasing angles on sides? [message #64397 is a reply to message #64392 ] Mon, 18 March 2013 23:52 UTC Go to previous messageGo to next message
May I suggest that you take a look at OpenSCAD? (www.openscad.org)
This bit of code:
$fn=6;
r=[0,1,2,3,5,8,13,21,34,55,89];
for (i=[1:10]) {
translate([0,0,i])cylinder(r1=10+r[i-1]/10,r2=10+r[i]/10,h=1 ,center=true);
would produce this:
index.php?t=getfile&id=29231&private=0
  • Attachment: pyramid.jpg
    (Size: 33.14KB, Downloaded 119 time(s))
Re: Best way to design a hexagon with increasing angles on sides? [message #64398 is a reply to message #64392 ] Tue, 19 March 2013 00:23 UTC Go to previous messageGo to next message
It depends on what software you are using. This was done in Sketchup by making vertical faces down from the top, then rotating each one in turn. I then extended the vertical lines to meet the ground plane. Then joined the end points together.
http://skfb.ly/5kj3hf1d0
Reminds me of a 'Dalek'
[Updated on: Tue, 19 March 2013 00:29 UTC]
Re: Best way to design a hexagon with increasing angles on sides? [message #64449 is a reply to message #64398 ] Tue, 19 March 2013 22:31 UTC Go to previous messageGo to next message
Woah, thanks fellas! That programmers shape builder is pretty interesting. I'll also have to check out sketchup. I should have been a bit more clear about my model, which I've nearly completed. If anyone has time to check out the attachment, I have a question.
You'll see that the top is a 6 sided face, the bottom 12 sided. This way the bottom can flare out, and each of the larger bottom edges are to be increasingly titled. Starting at nearly straight up and down, 180 deg, and increasing maybe 2 or 3 deg per edge. I have more or less accomplished this by grabbing the edges in ortho top view and dragging them along the y axis by increasing amounts, then rotating the entire mesh in edit mode, and moving on to the next edge. I'd prefer to do it with angles rather than guessing with grab, is there a way to do that?
Re: Best way to design a hexagon with increasing angles on sides? [message #64453 is a reply to message #64449 ] Tue, 19 March 2013 23:38 UTC Go to previous messageGo to next message
I did this originally but thought you only wanted six sides not twelve.
index.php?t=getfile&id=29321&private=0
Re: Best way to design a hexagon with increasing angles on sides? [message #64454 is a reply to message #64453 ] Tue, 19 March 2013 23:41 UTC Go to previous messageGo to next message
Beautiful!
For the sake of learning, can I ask why this shape I made doesn't seem to be solid? When I do a difference modifier it won't respond correctly.
Re: Best way to design a hexagon with increasing angles on sides? [message #64455 is a reply to message #64454 ] Wed, 20 March 2013 00:05 UTC Go to previous messageGo to next message
Shapeways Crew
1. your normal where wrong (ctrl + N in edit mode will fix it)
2. you got object inside other one and not hollow object.
i modified your file so you can make difference correctly
PS: watch out for thin walls (don't know your scale but 0,08 mm is not enough)
[Updated on: Wed, 20 March 2013 00:05 UTC]
The only thing that limits us is our imagination.
Re: Best way to design a hexagon with increasing angles on sides? [message #64456 is a reply to message #64455 ] Wed, 20 March 2013 00:26 UTC Go to previous messageGo to next message
Okay one last thing before I print.
I want to mount this thing on a CD player motor, which means I need a hole in the bottom that is a circle of 15mm. I can make that easy enough, the problem is that I want it to be centered on the shape by MASS, so that it doesn't spin out of control. How might I go about that?
G
Re: Best way to design a hexagon with increasing angles on sides? [message #64457 is a reply to message #64456 ] Wed, 20 March 2013 00:30 UTC Go to previous messageGo to next message
Shapeways Crew
ctrl+alt+shift+C - origin to ceneter of mass
and than move your cutter for hole accordinly
Re: Best way to design a hexagon with increasing angles on sides? [message #64460 is a reply to message #64457 ] Wed, 20 March 2013 01:36 UTC Go to previous message
Awesome! Only problem is... can't seem to figure out how to move the cutter to that origin point. If I select it, the origin moves to the origin of the cutter.
Previous Topic:After all the iPhone Cases, now a really useful project!
Next Topic:blender: why can't I difference modify this?
