My Shop problems
My Shop problems [message #58288] Sun, 09 December 2012 21:17 UTC Go to next message
avatar pinkus12001  is currently offline pinkus12001
I am having problems setting up the extended description in My Shop. For one it will not save unless I have input a Google Analytics code. I have inserted a generic code i.e.UA-0123456-0 which has oivercome this issue but I haven't a clue what Google analytics is and why I need it to save my changes? Secondly I have tried adding some hypertext links i.e. http://miniandbeyond.blogspot.co.uk/ into my extended description and no matter how I do it (cut and paste, and , etc) it does not work on the public shop front. I have trawled the forums for information but nothing I have tried has worked. Is it me Confused ? Additionally one post mention a My Shop settings but where do I get into this as nothing shows up on the My Shop webpage?
Thanks, Richard
[Updated on: Sun, 09 December 2012 21:21 UTC]
Re: My Shop problems [message #58291 is a reply to message #58288 ] Mon, 10 December 2012 01:23 UTC Go to previous messageGo to next message
Google Analytics should be optional. Otherwise, you found a bug.
For links, you have to write HTML tags. For example:
Blah blah <a href="http://miniandbeyond.blogspot.co.uk/ ">more info in the blog</a> blah blah
will make "more info in the blog" be a link to your blog.
Edit: there seems to be another bug, this time with the CSS for "code" in forum posts., it appears as black text over dark grey (then white border and a dashed blue line)... Select the text to see what it says in the meanwhile.
[Updated on: Mon, 10 December 2012 01:29 UTC]
Re: My Shop problems [message #63702 is a reply to message #58288 ] Sat, 09 March 2013 23:25 UTC Go to previous message
avatar MrNibbles  is currently offline MrNibbles
For what it's worth at this point I had the same problem using Microsoft Explorer. Everything was fine using Google Chrome.
I also had problems adding photos to models.
Previous Topic:Incorrect Link on Community Page
Next Topic:Image Preview Has Holes, Animated Preview is Perfect
