Home » Community » General Discussion » Questions
Questions [message #63668] Sat, 09 March 2013 16:22 UTC Go to next message
avatar iwinsome  is currently offline iwinsome
This is a doillie model with a lot of negative spaces like holes and I would like to know if I am able to get all the details.
index.php?t=getfile&id=28705&private=0
Re: Questions [message #63678 is a reply to message #63668 ] Sat, 09 March 2013 19:05 UTC Go to previous messageGo to next message
What material do you want to print this in?
How large is the object, and how large are the holes?
Re: Questions [message #63686 is a reply to message #63678 ] Sat, 09 March 2013 20:04 UTC Go to previous messageGo to next message
It was about 20x8 cm and size of holes are more than 1mm. I would like print in white plastic or ceramic.
Re: Questions [message #63695 is a reply to message #63686 ] Sat, 09 March 2013 20:49 UTC Go to previous messageGo to next message
20 centimeters?? That's going to be very expensive.
http://stonysmith.com/wired/VolumeEstimator.asp?L=200&W= 200&H=80&T=0&S=1
for the number of holes you have, the price will be around 1/3 of that cost, but still pricey.
If you were wanting only 8mm thick, that'd be much more reasonable: (again, about a third of this cost because of the holes)
http://stonysmith.com/wired/VolumeEstimator.asp?L=200&W= 200&H=8&T=0&S=1
For everything except ceramic, 1mm holes are plenty big enough.. for ceramic they need to be 3mm.
[Updated on: Sat, 09 March 2013 20:50 UTC]
Re: Questions [message #63700 is a reply to message #63695 ] Sat, 09 March 2013 23:09 UTC Go to previous message
Thank you so much! Smile
Previous Topic:Help! Full collor sandstone almost $500
Next Topic:minimum space between meshes?
