MESHLAB Uniform mesh resampling PROBLEM*
MESHLAB Uniform mesh resampling PROBLEM* [message #63325] Wed, 06 March 2013 02:30 UTC Go to next message
avatar Spacetime  is currently offline Spacetime
Hey Yall,
I've been looking for a good way to add thickness to my models for uploading. I'm also trying to teach my students how to hollow models. We have been using Zbrush with good results but there is no way to be precise with this.
I have been trying to use MESHLAB's Uniform Remeshing filter but not with much luck. The settings I am testing I have attached a screenshot of.
After using this function I do have a new layer called offset but there doesn't seem to be anything in it??? No faces or vertices I'm very confused could someone please help.
C
index.php?t=getfile&id=28515&private=0
  • Attachment: REmesh.jpg
    (Size: 418.91KB, Downloaded 250 time(s))
http://www.shapeways.com/shops/spacetime
Re: MESHLAB Uniform mesh resampling PROBLEM* [message #63337 is a reply to message #63325 ] Wed, 06 March 2013 09:16 UTC Go to previous messageGo to next message
The trick is to create and inner and outer offset shells, then remove the outer shell.
Check 'Absolute Distance' and use a positive abs offset value to create the both inner & outer offset shells.
Used the 'select connected components in a region' tool (underlined in red in the image) and just touch the outer shell with the lasso box.
Hit delete and turn off visability for the original mesh to see the inner offset shell.
index.php?t=getfile&id=28524&private=0
Re: MESHLAB Uniform mesh resampling PROBLEM* [message #63375 is a reply to message #63337 ] Wed, 06 March 2013 19:51 UTC Go to previous messageGo to next message
OK this is very helpful! But I still am a bit confused or curious if there is a way to control the thickness?
What I mean is there a way I can chose exactly how thick the offset mesh is going to be?
The values I'm entering that have been working for me are attached to the image below (which are working). It seems that by changing these just a little I get a really messed up offset mesh?
Do you have recommended settings?
Thanks much
C
index.php?t=getfile&id=28558&private=0
Re: MESHLAB Uniform mesh resampling PROBLEM* [message #63376 is a reply to message #63325 ] Wed, 06 March 2013 20:17 UTC Go to previous messageGo to next message
If you know the dimensions of the model, you can specify the offset as the ABS value, otherwise you're stuck to calculating the offset needed. From the numbers for 'Precision' it looks like the model has largest length as 6.39 units, enter the 'world units' value for the wall thickness you need in the offset abs box.
The reccommended settings are those that are right for the size of the model and the material that the model is intended to be printed in.
Re: MESHLAB Uniform mesh resampling PROBLEM* [message #63379 is a reply to message #63376 ] Wed, 06 March 2013 21:12 UTC Go to previous messageGo to next message
Okay great ! So The precision that I have now set at 2 is ok?
It seems to do the same things wether that is 1 or 2
I finally understand the offset abs box but what is the precision box for?
Re: MESHLAB Uniform mesh resampling PROBLEM* [message #63414 is a reply to message #63325 ] Thu, 07 March 2013 07:43 UTC Go to previous messageGo to next message
Presicion is how fine you want the new mesh to be. The smaller the number, the more smaller faces will be generated.
Re: MESHLAB Uniform mesh resampling PROBLEM* [message #63453 is a reply to message #63414 ] Thu, 07 March 2013 17:27 UTC Go to previous message
Thank you everyone!!!! Very Happy
This is super helpful and I have it working quite well now- such a great community
ALL THE BEST!!!!!
C
Previous Topic:Blender and UV Mapping
Next Topic:Any free 3D boolean software?
