I have a new simple model that I was looking to get printed and the pricing seems very high for the amount of material that I believe it is using.
Are there any suggestions to get my cost down?
I can't tell how thick your model is. In general for WSF I've found 1.3mm to be a pretty good thickness. It's fairly strong and I suspect for a clip would be good. This does depend how much force will be on that clip but its a good stiffness for a lot of objects. Director 3D Tools
Right now I have this at 2mm as I was following the guidelines for wall thickness.
There will be very little force on this if at all and essentially is just holding a few paper tubes with a ball on the end inside a pouch (I will probably have 6 of these)
Cutting out some cool patterns makes most models more beatiful and less expensive, don't know if that would work on your model but i would give it a try given the pricing on this.If it doesn't look good it's not designed by us.
