Why i got in my model different measurements ?
Why i got in my model different measurements ? [message #63293] Tue, 05 March 2013 20:47 UTC Go to next message
avatar numarul7  is currently offline numarul7
Knowledge Expert
http://www.shapeways.com/model/957220/lonelywolf.html
My model is :
Original Bounds
In: 2.5 w x 2.8 d x 0.3 h
Cm: 6.4 w x 7.2 d x 0.8 h
What is this ???? :
Oriented Bounds (used for determining printability)
In: 2.5 w x 2.5 d x 0.3 h
Cm: 6.4 w x 6.4 d x 0.8 h
I don`t understand what is happening , i modeled the pendant in exact measures , same measures are in NETFAB http://www.netfabb.com/basic.php
What this mean when the printable MAXIMUM for http://www.shapeways.com/materials/strong-flexible-design-gu idelines it is 650x350x550mm (White) · 230x180x130mm (Black) · 150x150x150mm (Polished & Dyed)
I mean my pendant is neither over that MAXIMUM and is chopped out ?
Even on I.Materialise site on test page of the site http://i.materialise.com/3dprintlab/instance/ce1c70c6-c679-4 ee5-b566-ea95a45eccd2 i get 6.4 w x 7.2 d x 0.8 h and not Orieted Bounds.
The hole for chain is 3.5 mm with the "Oriented Bounds" means that the chain hole is 3.0 mm and renders my pendant useless cause a chain is 3 mm thick , when I modeled 3.5 mm exact measure , same measure in NETFAB reported.
How can i make another product now when the measures are reported incorrect ?
numarul7 jewelry and design
Re: Why i got in my model different measurements ? [message #63295 is a reply to message #63293 ] Tue, 05 March 2013 20:56 UTC Go to previous messageGo to next message
If you go into edit mode on your item you will see the Original Bounds and the Oriented Bounds. The oriented bounds is the smallest possible bounding box of the item. This is for determining density discounts and print-ability in materials. So look at your item in edit mode, for a box that looks like the attached image. The Original bounds should match what you are expecting.
index.php?t=getfile&id=28492&private=0
Re: Why i got in my model different measurements ? [message #63304 is a reply to message #63295 ] Tue, 05 March 2013 22:00 UTC Go to previous messageGo to next message
Knowledge Expert
So that means that my design will print in the "Original Bounds
" size ?
That is why i`m asking cause i get confused by this reports.
[Updated on: Tue, 05 March 2013 22:04 UTC]
Re: Why i got in my model different measurements ? [message #63332 is a reply to message #63304 ] Wed, 06 March 2013 06:46 UTC Go to previous message
Yes, don't worry nothing gets chopped of Smile
In the case of oriented bounds, it only means that you could rotate the object in such a way that it would fit into the smaller bounding box show there.
(for the reasons Michael mentions)
Previous Topic:Why Is my model not for sale?
Next Topic:Incorrect Link on Community Page
