| Biggest printable piece? [message #63202] Mon, 04 March 2013 19:45 UTC |
Hi guys!
I'm thinking of making a couch and assuming that you really can't print the whole thing (haven't read a whole lot about it to be honest).
So let's play with the thought of getting the biggest possible solid part out of the 3D printer - How big could you get it (length, width, depth)?
/J.
| Re: Biggest printable piece? [message #63203 is a reply to message #63202 ] Mon, 04 March 2013 19:51 UTC |
The largest bounding box is 650x350x550mm. So it would take several pieces to print a couch, and would be very very expensive.
| Re: Biggest printable piece? [message #63204 is a reply to message #63203 ] Mon, 04 March 2013 19:55 UTC |
Thanks for the quick reply! That's what I thought initially...
| Re: Biggest printable piece? [message #63206 is a reply to message #63202 ] Mon, 04 March 2013 20:00 UTC |
The max volume for WSF (Nylon) is 650x350x550mm.. the biggest size for Steel is 1000x450x250mm. Steel might be a bit hard to sit on.
As for WSF, if you made it a solid bock at the maximum boundary, it'd cost you $175,000 (not counting the 20% density discount) and for a standard (single person) seat, you'd likely have to have two of them.
If you made the same block with completely hollow with 3mm walls, it'd still be rouglhly $6,500 per block.
Of course, I'm sure that Shapeways would love to have the business. <grin>
| Re: Biggest printable piece? [message #63213 is a reply to message #63206 ] Mon, 04 March 2013 21:16 UTC |
Haha, sweet mother of god! I guess that I'll try to carve it out of wood instead!
| Re: Biggest printable piece? [message #63548 is a reply to message #63213 ] Fri, 08 March 2013 10:03 UTC |
| 19JW89 wrote on Mon, 04 March 2013 21:16 | Haha, sweet mother of god! I guess that I'll try to carve it out of wood instead!
If u decided not to carve it out of wood can u write about how did u printed it ? It is really interesting and I think it would be a top of speech for a while in a public if u try to do that .
