Home » Support » 3D Design » pricing error?
pricing error? [message #6069] Wed, 26 August 2009 21:37 UTC Go to next message
avatar Jettuh is currently online Jettuh
hi guys:
http://www.shapeways.com/model/47953/1.html
my object shows $0.00 Laughing
but the wallthickess is 1,2 mm and the lengt is about 16cm,, whats going on? error?
Re: pricing error? [message #6088 is a reply to message #6069 ] Thu, 27 August 2009 16:11 UTC Go to previous messageGo to next message
Make sure your Normals are properly oriented. the upload is supposed to catch inverted normals but I have seen it fail a few times.
If you need help with normals, let me know.
Re: pricing error? [message #6090 is a reply to message #6088 ] Thu, 27 August 2009 16:37 UTC Go to previous messageGo to next message
no problems with normals Wink
ill try uploading it again when the train is finished
Re: pricing error? [message #6093 is a reply to message #6090 ] Thu, 27 August 2009 17:05 UTC Go to previous messageGo to next message
Ya you do. I can tell from the picture.
I suspect you made a mirror copy, yes?
Are you using Blender?
Re: pricing error? [message #6095 is a reply to message #6069 ] Thu, 27 August 2009 17:21 UTC Go to previous messageGo to next message
Yes i did made an mirror, but the last time i made a mirror on the VIRM (the other dutch train) it worked...
this time it was mirrored the same way
i use 3dsmax7
Re: pricing error? [message #6098 is a reply to message #6069 ] Thu, 27 August 2009 18:00 UTC Go to previous messageGo to next message
Mirrored objects in max are indeed also normally inverted.
Usually shapeways corrects inverted models, apparantly not always.
And not to spam my own work :
http://www.shapeways.com/forum/index.php?t=msg&th=714&am p;start=0&S=9df68a044f3dbef091b420e81b90b373
But the max pricing tool will detect any inverted volumes.
Re: pricing error? [message #6145 is a reply to message #6098 ] Sat, 29 August 2009 15:42 UTC Go to previous messageGo to next message
Hey guys,
got the good results now, but the shapeways price on the website says: 23.87,,, and the old version of virtox i use,, where the old price is $1.68 for WSF, it says my object is $23.58.
i don't want to say i have a diffrence of about 30cents, but that was virtox his old calculator, with the price of $1.68 for the WSF,,,
so the price for the shapeways objects after the new discount (see shapeways newsletter) is not on yet?
cause that would mean the objects should be cheaper?
Re: pricing error? [message #6246 is a reply to message #6145 ] Wed, 02 September 2009 21:44 UTC Go to previous messageGo to next message
avatar jvo  is currently offline jvo
I have one on the topic of pricing error. The FAQ states that "The price of a model depends on the volume...". I recently uploaded a model of which the price calculation did not seem correct to me, so I uploaded some test models and here are the results:
test1: A 10x10x10 mm cube. Volume is obviously 1 cubic cm. Price is $ 3.57. Lets call this the unit price.
test2: A 10x10x10 mm cube with a 6x6x6 inverted cube inside. The volume is 0.784 cubic cm. (1 - 0.6 x 0.6 x 0.6.) The price is 89.1% of the unit price. Do note that I did not put holes in the sides, so the excess material would be trapped and shipped.
test3: Here it really comes. This model resembles my model more and has all room to let excess material out. A 10x10x10 mm cube consisting only of its ribs in 2 mm. The volume is 0.352 cubic cm. (8 x 0.2 x 0.2 x 0.2 + 12 x 0.2 x 0.2 x 0.6.) The price however still sticks at 67.8% of the unit price. (The model is one manifold volume, no overlaps.)
[Updated on: Wed, 02 September 2009 21:48 UTC]
Re: pricing error? [message #6247 is a reply to message #6246 ] Wed, 02 September 2009 21:48 UTC Go to previous messageGo to next message
There is now also a fixed price of $1.50 added to the price of each piece. You need to subtract it from the given price to get your unit (per volume) price. I have found pretty good accuracy of price = 1.50 + 1.50*Volume in CC.
Re: pricing error? [message #6248 is a reply to message #6247 ] Wed, 02 September 2009 21:53 UTC Go to previous message
Thanks, that solves it. Not directly with $ 1.50. But it does after I add 19% tax to that $ 1.50. So, big is the way to go Razz
Previous Topic:Non manifold?
Next Topic:Parts Not Attached
