| wall thickness for Stainless steel [message #62406] Tue, 19 February 2013 19:55 UTC |
If I were considering making a small pendant, under an inch in diameter, would I still be required to make all walls 3mm thick? It seems like it would relly more on proportions to me, but idk.
EDIT: I'm talking about being printed in stainless steel btw
[Updated on: Tue, 19 February 2013 19:57 UTC] "Hm, I'm so hungry I could eat an entire cow. Gerard, fire up the printer!"
| Re: wall thickness for Stainless steel [message #62407 is a reply to message #62406 ] Tue, 19 February 2013 20:07 UTC |
As it says on the material page
"Walls under 3mm might be printable depending on your design's structure - In general, if your model is well supported (thicker walls weave in with thinner walls), or your thin walls are small relative to your structure (small rings and cufflinks), then you could print down to 1.5mm thin walls. To learn more about this, take a look at the next few design tips."
Under that is a link to the design guidelines which explains how under 3mm is allowable
| Re: wall thickness for Stainless steel [message #62417 is a reply to message #62407 ] Tue, 19 February 2013 21:22 UTC |
Thanks, I must have over-looked this
