Home » Support » 3D Printing » the finish in black strong & flexible is similar to the other colors?
the finish in black strong & flexible is similar to the other colors? [message #62089] Fri, 15 February 2013 04:00 UTC Go to next message
avatar joseng  is currently offline joseng
hello.
i´m designing some cases and i already have some printed in the strong and flexible materials. i want to print
a new ones but in black strong and flexible, do they have the same finish of the other flexible colors? or what material
do you think is most suitable for cases?
Re: the finish in black strong & flexible is similar to the other colors? [message #62112 is a reply to message #62089 ] Fri, 15 February 2013 14:39 UTC Go to previous message
Black SF should be similar to White SF. For cases, I'd used the other colors of SF or polished White as the surface is more of a finished product feeling. Seeing cases are handled often, you probably want to make them a little loose, and coat them in a finish that will keep them clean looking longer.
Previous Topic:High output STL detail
Next Topic:Best cleaning methods
