Home » Community » It arrived! » Treble clef rings
Treble clef rings [message #61548] Thu, 07 February 2013 23:48 UTC Go to next message
avatar StuffBySteve  is currently offline StuffBySteve
These turned out beautifully! I love printing in metal Very Happy
http://shpws.me/n7mt
http://images1.sw-cdn.net/model/picture/674x501_791309_749890_1357951830.jpg
http://images1.sw-cdn.net/model/picture/674x501_791309_749889_1357951816.jpg
http://shpws.me/n7mI
http://images1.sw-cdn.net/model/picture/674x501_791385_749915_1357955644.jpg
http://images1.sw-cdn.net/model/picture/674x501_791385_749904_1357952729.jpg
Re: Treble clef rings [message #61554 is a reply to message #61548 ] Fri, 08 February 2013 01:05 UTC Go to previous messageGo to next message
avatar Tjsolo  is currently offline Tjsolo
That looks awesome Smile
Tj Solo
Re: Treble clef rings [message #61596 is a reply to message #61548 ] Fri, 08 February 2013 13:48 UTC Go to previous messageGo to next message
Excellent!
Re: Treble clef rings [message #61699 is a reply to message #61596 ] Sat, 09 February 2013 23:08 UTC Go to previous messageGo to next message
Yes! Great design idea! Very Happy
What is the wall thickness on that though? It appears to have a minimum of 1 mm and a maximum of 1.5 mm. Yet, the design rules for stainless call for a minimum wall of 3 mm. I tend to shy away from designing for stainless cuz of this bulky wall constraint. But what you have printed here looks amazing! Am I not understanding something about the design rules for this material? I would love to know. Smile
Patterns For CNC
Re: Treble clef rings [message #61705 is a reply to message #61699 ] Sun, 10 February 2013 00:12 UTC Go to previous messageGo to next message
Thanks everyone! Smile
UniverseBecoming wrote on Sat, 09 February 2013 23:08
The design tips give some more information on this, but I find that rings work well even when they're thin, since they support themselves well. The second ring is probably as thin as you can go no matter what, and it helps that the separate thin parts connect to each other often. It depends mostly on what you're making, and the size. Just try it, and see if it's accepted!
Here's the measurements of the smaller one (bronze)
index.php?t=getfile&id=26973&private=0
index.php?t=getfile&id=26974&private=0
  • Attachment: 1.jpg
    (Size: 64.33KB, Downloaded 212 time(s))
  • Attachment: 2.jpg
    (Size: 138.11KB, Downloaded 210 time(s))
Re: Treble clef rings [message #61706 is a reply to message #61705 ] Sun, 10 February 2013 00:30 UTC Go to previous messageGo to next message
Thanks for the detailed reply! Yes, I'll try submitting something questionable and see what happens. Smile
Patterns For CNC
Re: Treble clef rings [message #61867 is a reply to message #61548 ] Tue, 12 February 2013 13:03 UTC Go to previous messageGo to next message
Yes, that wall thickness question was just what I was thinking myself. Very confusing as to what I see printed and the rejections I get. I would never have submitted this for printing in s/steel! You may be right in that being circular it helps, and the very thin part is quite short...
Glenn
Re: Treble clef rings [message #61886 is a reply to message #61867 ] Tue, 12 February 2013 15:49 UTC Go to previous messageGo to next message
It definitely makes a difference- if I submit it with the same dimensions, but flat instead of as a ring, it isn't printable in steel.
Taking a quick look through your shop, I'd bet that things like your mask ring, hand ring, and Spartan helmet ring would be printable in steel.
Re: Treble clef rings [message #61888 is a reply to message #61886 ] Tue, 12 February 2013 16:53 UTC Go to previous message
You could be right. I'll have to try them. I always print in silver which is not exactly the cheapest way to go!
Glenn
Previous Topic:A Heron
Next Topic:''Pulse'' Modern Cross
