| Creating threaded holes for screws [message #46317] Mon, 02 April 2012 13:31 UTC |
I have created a model to be 3D printed that requires a threaded hole for screws. I intend to use the "White, Strong, and Flexible" material. According to Shapeways support, this material will not withstand having a screw threaded into it multiple times.
Has anyone faced a similar situation? Did you have threaded metal insets which could be plugged into the hole that the screw can be inserted into? Is there another solution to this problem? I'd really appreciate help! Thanks.
| Re: Creating threaded holes for screws [message #46399 is a reply to message #46317 ] Tue, 03 April 2012 17:17 UTC |
I commonly tap holes in WSF (just leave the right diameter hole in the model and then use a tapping set) for bolts. I haven't ran into any problems. I would assume the problem would arise if you didn't tape the hole and just tried to use a self threading screw just like any other material.
| Re: Creating threaded holes for screws [message #61883 is a reply to message #46317 ] Tue, 12 February 2013 15:27 UTC |
I tap holes in WSF, 2mm and 3mm for use with nylon screws. No problems yet. For steel screws and frequent use it may be best to use Helicoils or Timeserts.
