| PA 2200 Polyamide [message #61731] Sun, 10 February 2013 11:58 UTC |
Is White Strong Flexible actually the same as PA 2200 ? If it is then, did you notice that it is FDA approved safety for contact with food except for alcoholic foodstuffs? That's something I read from EOS. Could someone tell me that you found the same or different?
| Re: PA 2200 Polyamide [message #61734 is a reply to message #61731 ] Sun, 10 February 2013 13:35 UTC |
This topic seems to come up every few weeks - the problem is not the material as such, but the manufacturing process
which results in a porous structure with an open, uncleanable surface. You will have to find a foodsafe coating
(winery press varnish has been suggested in an earlier thread) or dispose of the parts after use.
| Re: PA 2200 Polyamide [message #61751 is a reply to message #61731 ] Sun, 10 February 2013 21:16 UTC |
Winery varnish, eh? Where is the thread on coating?
| Re: PA 2200 Polyamide [message #61753 is a reply to message #61751 ] Sun, 10 February 2013 21:29 UTC |
See here. (The forum search will not find it, as the German word Kelterlack was used)
