| Necklace part costs more than I thought [message #61538] Thu, 07 February 2013 19:40 UTC |
I've made a part for a necklace, but I was suprised when I saw the price for it.
I was wondering if someone could look at it and fix problems and other things that could bring the price up.
It is a square with tiny squares sticking out of it.
It was made in SketchUp 8.
Attachment: Part.skp
(Size: 838.19KB, Downloaded 22 time(s))
| Re: Necklace part costs more than I thought [message #61539 is a reply to message #61538 ] Thu, 07 February 2013 19:45 UTC |
Can you export it in *.stl format?
Only limit is your imagination.
http://www.shapeways.com/forum/index.php?t=msg&th=13879&start=0&
| Re: Necklace part costs more than I thought [message #61541 is a reply to message #61539 ] Thu, 07 February 2013 20:13 UTC |
Here you go
Attachment: Part.stl
(Size: 1.04MB, Downloaded 15 time(s))
Re: Necklace part costs more than I thought [message #61543 is a reply to message #61541 ] Thu, 07 February 2013 20:51 UTC |
Not sure which material you want to use but part of inner wall can be scaled out (make thinner wall)
try this (Attachment) (check units before uploading)
(Size: 242.95KB, Downloaded 13 time(s))
| Re: Necklace part costs more than I thought [message #61571 is a reply to message #61543 ] Fri, 08 February 2013 08:32 UTC |
Are the walls too thin to be made out of stainless steel?
| Re: Necklace part costs more than I thought [message #61628 is a reply to message #61571 ] Fri, 08 February 2013 19:05 UTC |
yes they are too thin
Min: 3mm. You have cca 2mm
