minimum size for a good polished?
minimum size for a good polished? [message #61361] Mon, 04 February 2013 23:23 UTC Go to next message
avatar Jose_narvaez  is currently offline Jose_narvaez
index.php?t=getfile&id=26679&private=0hello.
i just want to ask what should be the minimum size between wires for a good polished on the new color
for example like this model i am working on. these are not the real size of the wires and the space between them in the original image, but is the size
i want to work with it. do you think it will get a good polished?
  • Attachment: polished.png
    (Size: 145.56KB, Downloaded 122 time(s))
Re: minimum size for a good polished? [message #61370 is a reply to message #61361 ] Tue, 05 February 2013 02:19 UTC Go to previous messageGo to next message
Just on gut feeling, you should increase the mesh size a bit, maybe 0.5mm. I can measure the polishing media in the morning and report back with my findings.
[Updated on: Wed, 06 February 2013 21:55 UTC]
Re: minimum size for a good polished? [message #61393 is a reply to message #61361 ] Tue, 05 February 2013 13:55 UTC Go to previous messageGo to next message
According the the design guidelines page "The polishing media (little 5mm diameter cylindrical pellets) can take off up to 0.1mm of the surface. For small details, this can rub away the sharp corners of your details and make them less crisp." So by that, inside your mesh won't get polished as well.
Re: minimum size for a good polished? [message #61398 is a reply to message #61393 ] Tue, 05 February 2013 15:23 UTC Go to previous messageGo to next message
Checkout this video: It'll give you an idea why very small items are not a good idea.
http://www.shapeways.com/blog/archives/1037-3d-model-polishe r-in-action.html
Re: minimum size for a good polished? [message #61435 is a reply to message #61398 ] Wed, 06 February 2013 00:58 UTC Go to previous message
ok that seems very clear to me. i was thinking according to your suggestions:1.2 mm for the wires and 3.5 mm for the mesh (the dimensions on the image are: 2mm for the wire and 5mm for the mesh) i don´t want to make it at this size because i don´t want the mesh looks bulky. according to your experience do you think in this measure it will get a good polished?
Previous Topic:Texture Map size for Full Color Sandstone?
Next Topic:Sterling bounding box
