| Painted Pen Holder [message #61332] Mon, 04 February 2013 17:15 UTC |
It's me again. Just yesterday I told about a coloring test with a spring.
Well, for the first time within the last few years I finished my sister's birthday present before her birthday. *cough*
Last year I did the silver fencing mask (that you can find in my shop) for her, but I started designing on her birthday itself, so no good timing.
I decided to paint the pen holder. It is designed to hold the pens in a comfortable angle and gets some stabilization from the wires (which I find appealing). Painting WSF is a bit like painting on silk, the color soaks through the material fast. This is responsible for those beautiful color changes.
I hope she will like it. She does not use Shapeways, that's why I can tell you :)
Yours, Marie
Attachment: 2.jpeg
(Size: 54.01KB, Downloaded 169 time(s))
| Re: Painted Pen Holder [message #61371 is a reply to message #61332 ] Tue, 05 February 2013 02:23 UTC |
Can you describe your painting process... paints used, any prep, finish added... curious minds want to know!
Glenn
| Re: Painted Pen Holder [message #61401 is a reply to message #61371 ] Tue, 05 February 2013 16:37 UTC |
Hi Glenn, thanks for your interest!
Painting in this style is pretty easy. I just dug out the water colors I used at school (Pelikan, but anything works).
Then I started by tapping wet color on the dry object and made it soak around by adding some water to the edges of the color spot.
Use different colors and let them flow into each other (some human support needed) and your done.
You see, no preparation, fun, relatively fast process.
Of course you have to be careful as water colors are not water proof :) . I looked out for some finishing technique and found CWestbrook's tutorial (http://shpws.me/lmko) on sealing with Polyurethane varnish. I am going to try that.
That's it.
Yours, Marie
| Re: Painted Pen Holder [message #61405 is a reply to message #61401 ] Tue, 05 February 2013 17:19 UTC |
Cool, thanks. Have a try with watered down acrylic paints. You wouldn't then have to put a top coat on if you didn't want to...
Glenn
| Re: Painted Pen Holder [message #61410 is a reply to message #61405 ] Tue, 05 February 2013 17:56 UTC |
That's an interesting idea. I'll definitely try it and have a look how fast it soaks through the nylon.
Thank you,
Marie
