Large order size
Large order size [message #60861] Sat, 26 January 2013 21:06 UTC Go to next message
avatar Spongeinside  is currently offline Spongeinside
Hi!
On a local internet forum there is a lot of interest for an item I've designed especially for them. At the moment I'm at 47 items in the strong and flexible material in white, red and blue (nobody wants purple or pink).
So I was wondering if there is a policy or something for discount on bulk orders?
If it ain't Dutch, it ain't much!
Re: Large order size [message #60869 is a reply to message #60861 ] Sat, 26 January 2013 23:55 UTC Go to previous messageGo to next message
No. There's no discount for 10, 100 or 1000 of an item. The prices here are purely based upon the volume of material you consume.
You can save some on the setup fee if you put multiple copies of an item into a single file, but they (should) be joined together such that the operators can deal with them as a single unit. This process is normally referred to as adding "sprues" - thin wires between the items, or in some cases if you wrap a container around the items (think wire basket) that would contain them.
Re: Large order size [message #60870 is a reply to message #60869 ] Sun, 27 January 2013 00:00 UTC Go to previous messageGo to next message
I was asking because the people on the forum wanted me to ask (got 'peer pressured' in to it Razz)
But for future reference it's good to know discount is only on volume, not on quantity Smile
Re: Large order size [message #60885 is a reply to message #60870 ] Sun, 27 January 2013 10:39 UTC Go to previous messageGo to next message
There's also a volume discount on models over 20cc with a density if 10% or more for the strong & flexible.
From http://www.shapeways.com/materials/strong-flexible;
"We also offer a volume and density discount on Strong & Flexible materials. For models that are greater than 10% dense (material volume divided by bounding box volume), after the first 20cm3, the remaining volume is calculated with a 50% discount."
Re: Large order size [message #60886 is a reply to message #60870 ] Sun, 27 January 2013 10:56 UTC Go to previous messageGo to next message
What you could do is say you wanted 20 Red, 20 Blue and 7 White, make 3 files to upload and buy.
Place 20 of the Models as close as you can together using as little space, then create a bounding cage like structure around them to make it easier for handling when they've been printed.
This way you'll save $28.50 on the startup costs and depending on how much material you use you may make a saving with the volume discount.
(I think it would be roughly $66 saved on startup costs used this way)
Hope this helps,
Tom.
Re: Large order size [message #61044 is a reply to message #60886 ] Tue, 29 January 2013 23:39 UTC Go to previous message
I generelly design 10x pieces containing 10 items of the same type.
For this issue I also have a blender script adding the sprues
So I save 13.5 of costs, which is in my case a significant price reduction.
Still waiting of a shapeway feature doing that. it has been asked for a couple of times.
- enabling sprues
- a 2nd stl containing the item on a sprue
- defining the expand direction, 2 items where placed along this axis, the ends of the sprue have to overlap
could be a simple method which is sufficient for my items. maybe somebody needing that can check it ....
Woody64
[Updated on: Tue, 29 January 2013 23:40 UTC]
More than 10000 items sold over SW (but still a hobby)
References: 3d Printing Industries, CNN, J. Burks, Ugly Duckling, M.Evans, Stop Motion Film,Computer BILD, How to Become a 3D Printing Entrepreneur, Brick History
More than 270 shop items (more then 146 already printed once) More the 500 successful Products (Items&material printed once)
Previous Topic:Can not be cleaned
Next Topic:Customer Service ++
