| Help with size [message #60852] Sat, 26 January 2013 18:25 UTC |
I'm new to shapeways and I'm having an issue with my uploads. When I upload a model the dimensions are not what I had originally put. I have a model that is 2.5 in long but after the upload it is 6.2 in long. Does anyone know what's going on or how to fix it. I am using Autodesk inventor and uploading in STL format.
Thanks in advance.
| Re: Help with size [message #60853 is a reply to message #60852 ] Sat, 26 January 2013 19:02 UTC |
What are all the dimensions x, y & z ? It may be that the model is in a defferent orientation to what's expected.
You might need to rescale the model before uploading to Shapeways.
| Re: Help with size [message #60854 is a reply to message #60852 ] Sat, 26 January 2013 19:03 UTC |
You have uploaded as inches instead of centimetres.
Bill Bedford
| Re: Help with size [message #60856 is a reply to message #60852 ] Sat, 26 January 2013 19:34 UTC |
You need to post the measurement option you chose at upload, and if at all possible the exact dimensions in you modelling program and a stl. We should figure out the problem at a glance. I am curious the exact dimensions SW had for it, I think a scaling problem is involved. if that dimension you gave was 6.35.The infamous 2.54 factor might be involved.
| Re: Help with size [message #60858 is a reply to message #60857 ] Sat, 26 January 2013 19:54 UTC |
It seems to be when I converted the file it only saves the cm dimensions and when I upload there is only options for inches (which is what I designed in originally), millimeters and meters. so if I scale everything up it should come out right.
| Re: Help with size [message #60859 is a reply to message #60852 ] Sat, 26 January 2013 20:34 UTC |
upload in meters, I figured it out.
| Re: Help with size [message #60879 is a reply to message #60859 ] Sun, 27 January 2013 03:08 UTC |
Just wanted to thank everyone who helped me out, I have figured out the issue and have had no further problems.
Again thanks.
