| materials FAQ [message #285] Tue, 22 July 2008 15:55 UTC |
Maybe I didn't look hard enough, but I can't find a description of the various materials. I'm guessing 'White Strong & Flexible' is stronger and more flexible and has less detail than 'White Detail' but maybe there is more to it than that (and the small price differences).
| Re: materials FAQ [message #286 is a reply to message #285 ] Tue, 22 July 2008 17:55 UTC |
rgc,
I'm sorry you did not easily find our "materials" page. Tomorrow I'll sit with some colleagues to go through how we can make that page easier to find.
This is the link to the page that gives you more information about the different materials:
http://www.shapeways.com/about/material-options
Should this not be sufficient, please tell me and I will explain it in more detail.
Joris
| Re: materials FAQ [message #287 is a reply to message #286 ] Tue, 22 July 2008 20:07 UTC |
that's exactly what i was looking for, sorry i couldn't find it either. i'm awful at UI design, so i won't try to help suggest a better place for it. thanks.
| Re: materials FAQ [message #292 is a reply to message #285 ] Wed, 23 July 2008 08:54 UTC |
Hi, (more) info about minimal thickness would also be welcome (I think).. especially for people with a tight budget
| Re: materials FAQ [message #293 is a reply to message #285 ] Wed, 23 July 2008 09:00 UTC |
Thats a good idea also. We will add this as soon as we can.
| Re: materials FAQ [message #315 is a reply to message #285 ] Thu, 24 July 2008 14:37 UTC |
One question: is there any of the materials which gets liquid under high temperature? Because without it, it's very difficult (for me) to make a metal object from it.
| Re: materials FAQ [message #316 is a reply to message #315 ] Thu, 24 July 2008 14:57 UTC |
Freeone,
The White Detail and White Transparent materials have melting points which are quite low.
All of our current materials are plastics so have comparatively low melting points.
But, If I understand you correctly your ultimate goal is to print a metal object?
| Re: materials FAQ [message #382 is a reply to message #316 ] Sat, 26 July 2008 17:20 UTC |
My target is, to finally make a cast metal object. If there is a plastic stage before that, who cares:) Anyway, thanks for the answer, i know what i wanted to know..
[Updated on: Sat, 26 July 2008 17:21 UTC]
| Re: materials FAQ [message #561 is a reply to message #293 ] Mon, 04 August 2008 11:12 UTC |
It'd be interesting (for me at least) to have a small sample of each available material.
Perhaps a small item, with minor differences, made with each process?
| Re: materials FAQ [message #563 is a reply to message #285 ] Mon, 04 August 2008 11:41 UTC |
We'll look into this. Right now we have some small objects on the site but nothing suitably tiny so you can order samples on the cheap. We'll see if we can cook up something.
| Re: materials FAQ [message #575 is a reply to message #563 ] Mon, 04 August 2008 15:47 UTC |
White Strong and Flexible Strength: Highest
mm.. can there also put the kN/mm² values in it.. how strong it really is.
are there coming more materials? like flexible that can be put on a UTP cable?
and is it possible that you can put the color black in the product.. because if it's pained it will not be nice..
groetjes..
| Re: materials FAQ [message #576 is a reply to message #575 ] Mon, 04 August 2008 15:59 UTC |
Janis, we do have those values, and we will add them to the next version of the materials page.
It is more flexible than a metal sping. I'm not sure if it is comparable to UTP.
We are working on a lot of new materials and colors and will update on that soon.
| Re: materials FAQ [message #603 is a reply to message #285 ] Tue, 05 August 2008 07:18 UTC |
maybe also bolling point when it's start to melt..
