| incorrect scale [message #60180] Mon, 14 January 2013 11:48 UTC |
When I import my model it loads at a smaller scale... should I scale it larger in 3Dmax and re-export the STL file?
| Re: incorrect scale [message #60181 is a reply to message #60180 ] Mon, 14 January 2013 12:35 UTC |
I used to get the same issue in Modo. I personally like to fix the model scale in NetFabb once I've exported it to STL so that my source file (Modo) is left intact. Whilst I'm fixing the scale, I also check the mesh is watertight etc... in netFabb
Netfabb is free but you can access additional tools if you upgrade to their professional version (I'm not using a professional version however). All the free tools generally covers what you need (checks the mesh is water tight, can fix scale etc...).
Check out my blog on my 3D print projects:
http://www.psychobob.co.uk
And here's my Shapeways shop!
http://www.shapeways.com/shops/PsychobobArts
