| Cant get ceramic option! [message #60113] Sun, 13 January 2013 02:30 UTC |
My model has an obvious base. But the preview shows it sideways and needs to be rotated 90 degrees. Is the problem? or is it that my piece has a hole? (torus coffee cup handles print so it cant be that reason). Any help would be appreciated.
| Re: Cant get ceramic option! [message #60114 is a reply to message #60113 ] Sun, 13 January 2013 03:07 UTC |
Attaching a file in a post does wonders In allowing others diagnose problems in a model. I am not trying to be a SA, but it does help considerably
| Re: Cant get ceramic option! [message #60116 is a reply to message #60114 ] Sun, 13 January 2013 04:39 UTC |
Enclosed here is the file. I guess linking to the uploaded stl file would be better..
Edit: I added chamfers where I could since I cant get a good fillet tool for sketchp
| Re: Cant get ceramic option! [message #60123 is a reply to message #60116 ] Sun, 13 January 2013 09:03 UTC |
Exporting DAE from Sketchup flips the model by 90 degrees. If you rotate the model in Sketchup before exporting, it will show up correctly in the Shapeways render...
-Marcus
| Re: Cant get ceramic option! [message #60164 is a reply to message #60123 ] Mon, 14 January 2013 03:15 UTC |
Ok for that: I got the proper orientation. thanks but no ceramic option yet
| Re: Cant get ceramic option! [message #60173 is a reply to message #60166 ] Mon, 14 January 2013 08:55 UTC |
You need to make the model page available to others for us to see it
But I'm guessing the item is either too small or too big, from Ceramics Design Gudelines
Min Bounding Box: x+y+z≥120mm - Max Bounding Box: 340x240x170mm AND x+y+z<=400mm
| Re: Cant get ceramic option! [message #60175 is a reply to message #60166 ] Mon, 14 January 2013 10:59 UTC |
| steve69 wrote on Mon, 14 January 2013 03:21 | ...But as seen here, solid inpector shows the piece is actually two parts! cant seem to get them glued...
There is an internal face in there that needs to be deleted...you may have to Select all > Right Click > Intersect faces with model to delete it.
As Paul suggests above, I think your part is too small for ceramics.
-Marcus
| Re: Cant get ceramic option! [message #60233 is a reply to message #60173 ] Tue, 15 January 2013 00:55 UTC |
Thanks for letting me know. Fact is, the materials page only mentions max size.
| Re: Cant get ceramic option! [message #60234 is a reply to message #60233 ] Tue, 15 January 2013 01:00 UTC |
If you click the "Design Guidelines" tab, there is more detailed info available, including the minimum size...
Attachment: ceramics.JPG
(Size: 83.79KB, Downloaded 77 time(s))
-Marcus
| Re: Cant get ceramic option! [message #60237 is a reply to message #60175 ] Tue, 15 January 2013 02:19 UTC |
| denali3ddesign wrote on Mon, 14 January 2013 10:59 |
Yes I redid the fillets in Sketchup and deleted the offending face inside the part by deleting the base face then putting it back after correcting.
When I re-uploaded to my account, still no ceramic. I doubled its size in Sketchup then reuploaded NOW IT WORKS!
Unfortunately I need the part to be 1.25in diameter not 2.5!
My solution: combine two identical parts joined with a breakable flue
EDIT: actually a connecting rod is not necessary, ill just put 2 parts in the dae file.
[Updated on: Tue, 15 January 2013 02:22 UTC]
