Home » Community » Work in progress » Would you give me feedback on this teacup before I print it?
Would you give me feedback on this teacup before I print it? [message #59730] Sun, 06 January 2013 19:28 UTC Go to next message
avatar dwygre  is currently offline dwygre
I am a first time 3D designer and printer.
I have a teacup I designed in Google Sketchup (see attached file). The teacup, when exported to a DAE file, is accepted by Shapeways when I upload it.
However, before I print it in white glossy ceramic I wanted to get some feedback. Do you see any issues with the model that might lead to unexpected results upon printing?
Thanks in advance for your help!
Re: Would you give me feedback on this teacup before I print it? [message #59733 is a reply to message #59730 ] Sun, 06 January 2013 21:15 UTC Go to previous messageGo to next message
Check the 'Design rules on this page especially 'curve your edges' and the minimum wall thickness
http://www.shapeways.com/materials/ceramics-design-guideline s
I would suggest uploading your file to http://cloud.netfabb.com/ in STL format. They will union the two shells together i.e. where the handle goes inside the cup.
You can import the DAE into Meshlab and export it as an STL. http://meshlab.sourceforge.net/
Once it is unioned together properly import the fixed STL into Meshlab. Export as DAE so you can import it back into Sketchup to round the corners.
jacantdesign@gmail.com
Re: Would you give me feedback on this teacup before I print it? [message #59740 is a reply to message #59733 ] Sun, 06 January 2013 23:31 UTC Go to previous messageGo to next message
Thank you for the quick reply. A couple follow-up questions as I am still learning.
First, why do you suggest I unite together the shell of the cup and the shell of the handle? And if by unite you mean to make those two internal spaces continuous between each other, could I do that more simply just in Sketchup by deleting the walls of the handle that are inside the cup (thus making one continuous internal space)?
Second, the thinnest part of this teacup is the upper lip which is 2mm thick and Shapeways requires a minimal wall thickness of 3mm for ceramics. Is there any other company that can print ceramics with a smaller minimum wall requirement?
Thanks again for your help.
[Updated on: Sun, 06 January 2013 23:32 UTC]
Re: Would you give me feedback on this teacup before I print it? [message #59791 is a reply to message #59740 ] Mon, 07 January 2013 18:11 UTC Go to previous messageGo to next message
I suggested you union the shells together to make it easier to produce a fillet to the sharp edges where the two shells meet. If you can do it in Sketchup, all the better.
I have only ever dealt with Shapeways. So I do not know personally of any other company that would do this for you.
Re: Would you give me feedback on this teacup before I print it? [message #59814 is a reply to message #59791 ] Mon, 07 January 2013 22:38 UTC Go to previous message
I just realised.
Ceramic is based on the surface area cm². So, by making the walls 3mm, you will actually be using less material.
Previous Topic:First time uploader
Next Topic:Lighting Project Inspired by Architecture
