Home » Community » 3D modeler needed » urgent wall thickness fix needed, will pay!
urgent wall thickness fix needed, will pay! [message #59773] Mon, 07 January 2013 16:06 UTC Go to next message
avatar bellaclava  is currently offline bellaclava
Hi, I have a design that has just been rejected - need help from someone to fix errors with wall thickness. want to resubmit this design today, can pay $30 for a quick fix!
Please email me: ariellefalk@gmail.com
[Updated on: Sat, 12 January 2013 17:08 UTC]
Re: urgent wall thickness fix needed, will pay! [message #59774 is a reply to message #59773 ] Mon, 07 January 2013 16:17 UTC Go to previous messageGo to next message
If those are the only two areas that need fixing, I can do that in the time frame and for the money. The thickening will be 'psudo' but blended in, otherwise, from the looks of it, you'll need to start over.
Re: urgent wall thickness fix needed, will pay! [message #59777 is a reply to message #59774 ] Mon, 07 January 2013 16:32 UTC Go to previous messageGo to next message
Ok - Would you be able to take a look at the file to check if it's actually doable (just the few areas need fixing)? Here is the link to model to download the file: http://www.shapeways.com/model/856772/leaf_2_fix.html?key=b9 a75af3bb7b0111d470f11e210da100
Re: urgent wall thickness fix needed, will pay! [message #59782 is a reply to message #59777 ] Mon, 07 January 2013 17:05 UTC Go to previous messageGo to next message
The root of every petal/leaf will need thicknening upto to maybe 1 - 1.3mm, and with the physical texture of the surface, that's not a job for me, sorry.
Paul,
Re: urgent wall thickness fix needed, will pay! [message #59783 is a reply to message #59782 ] Mon, 07 January 2013 17:09 UTC Go to previous messageGo to next message
would this version of the model be easier to fix? http://www.shapeways.com/model/840403/crassula.html?key=89d4 49f21db83a7d99d596b95878f578
Re: urgent wall thickness fix needed, will pay! [message #59878 is a reply to message #59783 ] Wed, 09 January 2013 03:23 UTC Go to previous messageGo to next message
avatar el_Lopez  is currently offline el_Lopez
Hello Bella,
If your still in need of assistance I can get this completed for tomorrow.
Send me a PM and we can talk details.
Regards,
Eric
www.el-lopez.com
Re: urgent wall thickness fix needed, will pay! [message #59887 is a reply to message #59773 ] Wed, 09 January 2013 11:55 UTC Go to previous message
avatar hadriya9091  is currently offline hadriya9091
On the two shell pendant, you could add a stem that attaches from the head to the ring, and the bottom to the ring.
Another route would be going the relief way. I think if you add a bevel, like the edge of a coin it would take away from the cheap look. Shocked
H@driya
Previous Topic:I need a 3d modeler to take my sketch and make it into 3d...please help.
Next Topic:A modeler for a small pendant design
