Home » Support » 3D Applications » Can you bend the rules for a Steel Pipe?
Can you bend the rules for a Steel Pipe? [message #59253] Wed, 26 December 2012 22:22 UTC Go to next message
avatar Steps2light  is currently offline Steps2light
So the recommended thickness for stainless steel is 3mm.
If I am making something that is pipe like...can I get to a 1mm thickness? Is the part stronger if it is a cylinder?
Pipe is 12 inch in length with 2-5 inch diameter.
Re: Can you bend the rules for a Steel Pipe? [message #59537 is a reply to message #59253 ] Thu, 03 January 2013 08:14 UTC Go to previous message
avatar Mitchell Jetten  is currently offline Mitchell Jetten
I won't recommend to go up to 1mm, but 1.5mm should be fine if the structure supports it:
Walls under 3mm might be printable depending on your design's structure
In general, if your model is well supported (thicker walls weave in with thinner walls), or your thin walls are small relative to your structure (small rings and cufflinks), then you could print down to 1.5mm thin walls. To learn more about this, take a look at the next few design tips.
Kind regards,
Mitchell Jetten
Customer Service Agent
Shapeways
Previous Topic:What export type to use in Maya 2013?
Next Topic:Texture problems, EDIT: Solved it I think.
