Home » Support » 3D Printing » Printing tubes?
Printing tubes? [message #58831] Tue, 18 December 2012 19:36 UTC Go to next message
avatar Piers  is currently offline Piers
Recently I designed some flowers posted here
The stems i designed are simple tubes with internal diameter of 2.1mm , wall thickness is 1.1mm. The tube has printed correctly. It appears to have a hole running all the way through (I can drill to the length of the bit , and the material removed was in powder form).
After a few different attempt im still unsuccessful in removing the powder deeper within the tube.
My question is :
What is the minimum internal diameter for not only printing a tube but being able to clear it with ease?
Since SLS parts have a somewhat hydrophobic effect would bathing in something like Isopropanol help loosen the powder more?
Kind regards
Oh i got a new camera, and took this photo ..... shame to waste it Wink
index.php?t=getfile&id=24529&private=0
  • Attachment: rose.jpg
    (Size: 128.82KB, Downloaded 115 time(s))
formerly known as pdb
Re: Printing tubes? [message #58835 is a reply to message #58831 ] Tue, 18 December 2012 20:09 UTC Go to previous messageGo to next message
I like the Shapeways underneath Cool I'd try maybe some compressed air?
Re: Printing tubes? [message #58862 is a reply to message #58831 ] Wed, 19 December 2012 07:59 UTC Go to previous messageGo to next message
Hey Micheal
I tried compressed air with no luck.......that said if i had a finer nozzle on the air gun (something similar to a can of compressed air or a WD40), lowered the PSI and tried that way it may work. Will give it a go.
Since i havent figured out the stems I used the Shapeways box to hold the fiber optics in place and block any unwanted light.....worked surprisingly well Rolling Eyes
Re: Printing tubes? [message #58890 is a reply to message #58862 ] Wed, 19 December 2012 14:52 UTC Go to previous messageGo to next message
Yea, that's what I would get. A can of compressed air. Maybe try a pipe cleaner? The tiny ones you can find at a craft store or something.
Re: Printing tubes? [message #58899 is a reply to message #58831 ] Wed, 19 December 2012 17:55 UTC Go to previous messageGo to next message
Havent tried them but I assume that if a .5mm wire cant shift the blockage.
I forgot to take them into work today so will test the Isopropanol to see if it can loosen the powder and then try the pipe cleaner idea.
Thanks Micheal
Re: Printing tubes? [message #58921 is a reply to message #58899 ] Thu, 20 December 2012 03:05 UTC Go to previous message
Some people reported freezing allowed them moving apparently stuck parts. Maybe it works for holes too.
Previous Topic:Errors after customer has paid :(
Next Topic:Ceramics - Cm/2?
