| HO scale narrow gauge 25 foot cars [message #52026] Sat, 28 July 2012 13:32 UTC |
I'm planning on producing some of the rolling stock of the Ohio River & Western Railway, a 3 foot gauge railroad.They are suitable for both HOn30 and HOn3, there will be versions for both gauges.They are designed to sit on my trucks, available for both gauges.
The first one available is a flatcar, with or without stakes.
Here are the two versions with stakes,fitted with the appropriate trucks and couplers.
To weight the model I glued some strips of lead between the sills.I used EZ line to make the truss rods.
This is the HOn30 version, painted and fitted with micro-trains 1015 couplers.
There are two small supports for the handbrake wheel at one end.They need to be drilled out to accommodate whatever you use, I used some 0.4mm dia. brass rod.The finished model:
Coming next,gondolas.
Attachment: flatcar-1.jpg
(Size: 83.21KB, Downloaded 483 time(s))
Attachment: flatcar-2.jpg
(Size: 103.75KB, Downloaded 479 time(s))
Attachment: flatcar-3.jpg
(Size: 99.97KB, Downloaded 472 time(s))
Attachment: flatcar-4.jpg
(Size: 95.87KB, Downloaded 481 time(s))
| Re: HO scale narrow gauge 25 foot cars [message #52462 is a reply to message #52026 ] Fri, 10 August 2012 14:17 UTC |
I have updated the design, as part of the queen-post was too thin and fell foul of the thin walls rule.At least one order was rejected because of this.
The new version 'should' be ok.Apologies if you have been affected by this.There is a degree of uncertainty about detail parts and minimum wall thickness.
[Updated on: Fri, 10 August 2012 14:17 UTC]
| Re: HO scale narrow gauge 25 foot cars [message #52677 is a reply to message #52462 ] Wed, 15 August 2012 21:42 UTC |
The gondolas are now available.The same build method applies to them.
I'll post photos of a finished one later, when I've finished it!
| Re: HO scale narrow gauge 25 foot cars [message #62347 is a reply to message #58844 ] Mon, 18 February 2013 22:54 UTC |
I've now added a caboose at last.HOn3 and HOn30 versions, same body, different chassis.
The body and chassis are linked together for printing by some small linking pieces.Cut through these to separate them, inside you will find the roofwalks.
There are no queenposts, but there are guides and holes for the truss-rods.
I've not got very far with this yet, the ladder is just a suggestion for the end.It needs lots of handrails and a handbrake wheel.
Note, on this prototype model the chassis was slightly too short, hence the cut-outs in the body sides.This has been corrected now.
See the next post for more useful info, the chassis is the same.
Attachment: cab_3.JPG
(Size: 147.74KB, Downloaded 200 time(s))
Attachment: cab_4.JPG
(Size: 154.23KB, Downloaded 196 time(s))
Attachment: cab_2.JPG
(Size: 164.23KB, Downloaded 197 time(s))
[Updated on: Tue, 19 March 2013 19:12 UTC]
