Home » Community » It arrived! » A Tale of Two HO Wheel Stops
A Tale of Two HO Wheel Stops [message #58775] Mon, 17 December 2012 23:58 UTC Go to next message
Here's a comparison of essentially the same 3D design printed in two different materials - WSF and FUD.
The first pic is a rendering of the 3D design; the WSF part is slightly thicker to meet the 0.7mm min wall thickness required (FUD only requires a minimum 0.3mm wall thickness).
The second pic shows the delivered prints after spray painting mounted on Atlas HO Code 83 Flex Track. On my screen the parts in the pics are magnified to ten times actual size.
Surface details in WSF are there but vague and grainy; FUD is very sharp. Unsurprisingly the cost of the FUD parts is double the price of WSF.
If you shrink the pic of the painted parts to 10% (roughly actual size for the parts) all that extra detail in the FUD print disappears and both parts look alike.
The FUD prints are worth the extra cost if you're viewing them from 18 inches of less distance and can see the detail; at greater distances WSF is the way to go.
FUD prints are for sale here:
http://www.shapeways.com/model/832945/6-bolt-wheel-stop-fud- ho-10pk.html
http://www.shapeways.com/model/832902/6-bolt-wheel-stop-fud- ho-20pk.html
WSF prints are for sale here:
http://www.shapeways.com/model/774527/6-bolt-wheel-stop-ho-w sf-20pk.html
http://www.shapeways.com/model/778905/6-bolt-wheel-stop-ho-w sf-40pk.html
index.php?t=getfile&id=24495&private=0
index.php?t=getfile&id=24496&private=0
[Updated on: Tue, 18 December 2012 00:03 UTC]
Re: A Tale of Two HO Wheel Stops [message #58779 is a reply to message #58775 ] Tue, 18 December 2012 01:39 UTC Go to previous messageGo to next message
Even that FUD seems rougher than it should be to me.
I think some of my FUD prints are smoother.
Re: A Tale of Two HO Wheel Stops [message #58901 is a reply to message #58779 ] Wed, 19 December 2012 18:42 UTC Go to previous messageGo to next message
stonysmith said:
"Even that FUD seems rougher than it should be to me."
Yeah, most of the FUD wheel stop was in contact with support material when it was printed (can't be helped until selecting print orientation is an option). I didn't do any sanding before painting to see what the results would look like - it looks OK to the naked eye.
Re: A Tale of Two HO Wheel Stops [message #59036 is a reply to message #58901 ] Fri, 21 December 2012 17:48 UTC Go to previous message
One row on the N scale (1:160) version of the wheel stop was at the top of the print; the finish quality of one side is flawless. The part's 5.5mm long:
index.php?t=getfile&id=24652&private=0
Previous Topic:Ceramics just arrived
Next Topic:The Giver and Last Stand
