Home » Community » It arrived! » FOC Onslaught Upgrade Kit
FOC Onslaught Upgrade Kit [message #58397] Tue, 11 December 2012 14:29 UTC Go to next message
avatar TreadshotA1  is currently offline TreadshotA1
http://i811.photobucket.com/albums/zz31/Treadshot_A1/FOC%20Onslaught%20Upgrade%20Kit/PartsLayout.jpg
http://i811.photobucket.com/albums/zz31/Treadshot_A1/FOC%20Onslaught%20Upgrade%20Kit/HingeBuild1.jpg
http://i811.photobucket.com/albums/zz31/Treadshot_A1/FOC%20Onslaught%20Upgrade%20Kit/VehicleFullComplement1.jpg
A common problem with FOC Onslaught is for the green blaster he comes packaged with to get stressed. The connections on his vehicle mode (to his arm) force the plastic further than it can take. That, and let's face it:
Onslaught isn't Onslaught without twin huge cannons!
The FOC Onslaught Upgrade Kit provides fixes to both these issues. A new Hinge Blaster and two Hinges relieve plastic stress with a new attachment point while Twin Cannons provide the firepower and silhouette Onslaught deserves.
In robot mode, Onslaught gets a new pistol and two shoulder-mounted cannons, surprisingly not from Swindle!
Twin Cannons mount on Onslaught using the combiner ports on his shoulders. They can also be handheld using the 5mm pegs.
http://i811.photobucket.com/albums/zz31/Treadshot_A1/FOC%20Onslaught%20Upgrade%20Kit/Robot2.jpg
FOC Onslaught Upgrade Kit on Shapeways
http://i811.photobucket.com/albums/zz31/Treadshot_A1/FOC%20Onslaught%20Upgrade%20Kit/Robot1.jpg
http://i811.photobucket.com/albums/zz31/Treadshot_A1/FOC%20Onslaught%20Upgrade%20Kit/Robot3.jpg
http://i811.photobucket.com/albums/zz31/Treadshot_A1/FOC%20Onslaught%20Upgrade%20Kit/Robot4.jpg
Onslaught transforms into Combiner Torso mode, keeping both hinges on him. The Twin Cannons stack with his green blaster on his back for more firepower, and even the Hinge Blaster stows on the back!
http://i811.photobucket.com/albums/zz31/Treadshot_A1/FOC%20Onslaught%20Upgrade%20Kit/Torso1.jpg
http://i811.photobucket.com/albums/zz31/Treadshot_A1/FOC%20Onslaught%20Upgrade%20Kit/Torso2.jpg
Re: FOC Onslaught Upgrade Kit [message #58399 is a reply to message #58397 ] Tue, 11 December 2012 14:38 UTC Go to previous messageGo to next message
But, why is it called a Hinge Blaster? And why the two superfluous Hinges on Onslaught's legs?
In Vehicle Mode, Onslaught takes his new Hinge Blaster and turns it into a new attachment point for the green blaster!
http://i811.photobucket.com/albums/zz31/Treadshot_A1/FOC%20Onslaught%20Upgrade%20Kit/VehicleHinge1.jpg
http://i811.photobucket.com/albums/zz31/Treadshot_A1/FOC%20Onslaught%20Upgrade%20Kit/VehicleHinge2.jpg
http://i811.photobucket.com/albums/zz31/Treadshot_A1/FOC%20Onslaught%20Upgrade%20Kit/VehicleHinge3.jpg
The 5mm peg hole lets the green blaster attach to the back, right between the Hinges! No more stressed plastic, no more attaching to those two fiddly pages on his arms.
(And yes, other 5mm weapons can be attached as well)
http://i811.photobucket.com/albums/zz31/Treadshot_A1/FOC%20Onslaught%20Upgrade%20Kit/VehicleHinge4.jpg
http://i811.photobucket.com/albums/zz31/Treadshot_A1/FOC%20Onslaught%20Upgrade%20Kit/VehicleHinge5.jpg
http://i811.photobucket.com/albums/zz31/Treadshot_A1/FOC%20Onslaught%20Upgrade%20Kit/VehicleHinge6.jpg
And in the spirit of Hinge Blasters everywhere, Onslaught finally doesn't aim downwards anymore! Unlike the original connection, which left the gun pointing at the ground, the new connection lets Onslaught aim up, up, up!
The Hinge rotates through 360 degrees itself, only blocked by the vehicle itself and the ground, so Onslaught can aim all the way back at cars behind him if he wants.
http://i811.photobucket.com/albums/zz31/Treadshot_A1/FOC%20Onslaught%20Upgrade%20Kit/VehicleHinge7.jpg
Re: FOC Onslaught Upgrade Kit [message #58400 is a reply to message #58399 ] Tue, 11 December 2012 14:39 UTC Go to previous message
When it comes to war, though, more weapons is always better! Arm Onslaught with his full complement of weapons and roll into battle!
Onslaught's Twin Cannons plug into the 5mm holes on the hinge pieces, above the Hinge Blaster. Other 5mm weapons can be attached here as well.
http://i811.photobucket.com/albums/zz31/Treadshot_A1/FOC%20Onslaught%20Upgrade%20Kit/VehicleFullComplement2.jpg
http://i811.photobucket.com/albums/zz31/Treadshot_A1/FOC%20Onslaught%20Upgrade%20Kit/VehicleFullComplement3.jpg
http://i811.photobucket.com/albums/zz31/Treadshot_A1/FOC%20Onslaught%20Upgrade%20Kit/VehicleFullComplement4.jpg
Hope you all like the FOC Onslaught Upgrade Kit. Smile
As always, comments and criticisms are welcome and undoubtedly appreciated
Previous Topic:Captured Snowflake - Christmas Ornament
Next Topic:Bandit Skull Ring
