Home » Community » General Discussion » Cufflink dimensions
Cufflink dimensions [message #58015] Wed, 05 December 2012 14:14 UTC Go to next message
avatar PlainOrb  is currently offline PlainOrb
Hi there, I'm currently working on a cufflink for a client. I'm new to cufflink field, so I would appreciate if any one can share some information:
I need to know the distance between the two ends as shown below, preferably in mm.
index.php?t=getfile&id=23905&private=0
again, thanks in advance to anyone who share this dimension.
[Updated on: Wed, 05 December 2012 14:16 UTC]
Plain Orb
Re: Cufflink dimensions [message #58139 is a reply to message #58015 ] Fri, 07 December 2012 01:18 UTC Go to previous messageGo to next message
I found many cufflinks in the market with stem length from 12mm to 20mm. Do they just fit different cuff sizes ?
Plain Orb
Re: Cufflink dimensions [message #58165 is a reply to message #58015 ] Fri, 07 December 2012 13:58 UTC Go to previous messageGo to next message
I moved you to general, as I think you might find more help here.
Re: Cufflink dimensions [message #58169 is a reply to message #58165 ] Fri, 07 December 2012 15:21 UTC Go to previous messageGo to next message
Sure, Thanks
Plain Orb
Re: Cufflink dimensions [message #58172 is a reply to message #58169 ] Fri, 07 December 2012 15:55 UTC Go to previous messageGo to next message
I designed mine with a length of about 13mm, but that includes a slight bend so the design will stay upright..
Hope this helps!
index.php?t=getfile&id=24016&private=0
www.RayTomlinDesigns.com
Re: Cufflink dimensions [message #58240 is a reply to message #58172 ] Sat, 08 December 2012 13:51 UTC Go to previous messageGo to next message
Thanks! and your stem looks cool ~
Plain Orb
Re: Cufflink dimensions [message #58245 is a reply to message #58240 ] Sat, 08 December 2012 15:49 UTC Go to previous messageGo to next message
Thank you for the compliment! I worked really hard on it Very Happy
Ray
Re: Cufflink dimensions [message #58324 is a reply to message #58245 ] Mon, 10 December 2012 12:20 UTC Go to previous messageGo to next message
I design in Solidworks. I found multi-substance design will make the design process of cufflinks much more efficient. It allows you to play tricks on each part of the cufflink and combine them together at last when you think it's perfect.
Plain Orb
Re: Cufflink dimensions [message #58329 is a reply to message #58324 ] Mon, 10 December 2012 15:14 UTC Go to previous messageGo to next message
I use Blender 3d for all of my modeling.
What is " multi-substance design"? It may be called something else in Blender.. But I'm not familiar with it.
Ray
Re: Cufflink dimensions [message #58389 is a reply to message #58329 ] Tue, 11 December 2012 11:35 UTC Go to previous messageGo to next message
It means editing each part of the model independently and export the whole model as one part. That will bring you more flexibility during designing.
Plain Orb
Re: Cufflink dimensions [message #58401 is a reply to message #58389 ] Tue, 11 December 2012 14:42 UTC Go to previous message
Hmmm.. Interesting.
What i usually do is just make multiple copy iterations of each design... It took me about 5 different tries to get the shape above to how I wanted it. Now I just have it saved as a part that I can implant in a design. Very Happy It makes making new designs faster. Very Happy
Previous Topic:Why not...?
Next Topic:3D terrain model help - seems simple, but...
