Home » Support » 3D Design » Why is my Coffee Cup filled in?
Why is my Coffee Cup filled in? [message #57565] Tue, 27 November 2012 18:27 UTC Go to next message
avatar caseykrugman  is currently offline caseykrugman
I have a model that I'm trying to finish, and for some reason, not only is it $270 in ceramic, but the entire center of the cup is filled in. Anybody run into this before?
Re: Why is my Coffee Cup filled in? [message #57567 is a reply to message #57565 ] Tue, 27 November 2012 19:09 UTC Go to previous messageGo to next message
Your geometry probably had a hole around the top that wasn't closed. when MeshMedic goes about closing holes, it takes the simplest path.. and sealed the top.
If you could share your STL, there are several people about that could take a look and see what went wrong.
If you'd rather keep the file private, send it to me on a PM.
Re: Why is my Coffee Cup filled in? [message #57568 is a reply to message #57565 ] Tue, 27 November 2012 19:11 UTC Go to previous messageGo to next message
It's most likely filled because of some error in the model. And your price is so high because ceramics is price by surface area. That honeycomb is going to have a lot of surface area, and when you fix your model to have a hollow cup, your price is going to increase. One more And, your design looks too sharp and too thin for ceramics. Check out the rules for ceramics here.
Re: Why is my Coffee Cup filled in? [message #57614 is a reply to message #57565 ] Wed, 28 November 2012 16:03 UTC Go to previous message
it is hard to tell from the single image, but to me it looks suspiciously like an open
honeycomb mesh with a solid cone floating inside - which would probably explain
the high price (large surface area). Could mean wrong normals orientation on the
"real" cup shape that the honeycomb should be fused with, or simply CSG gone
wrong if you intended to subtract the cone from the cup shape in whatever modeling
program you used.
Previous Topic:How do I fix these corner gaps?
Next Topic:Traditional Clay and Wax Sculptor - Can I Scan Existing 3D Designs?
